Tip & How-To about Computers & Internet
Try these easy Firefox tweaks and you’ll see that you’re surfing the Internet from 3 to 30 times faster!
* To get started, open your Firefox web browser. In the address/location bar type about:config and then press your Enter key.
* In the Filter bar type network.http.pipelining. Then, double-click on this line under Preference Name in order to change the value from False to True.
* In the Filter bar type network.http.pipelining.maxrequests. Then, double-click on this line under Preference Name and change the value from 4 to a higher number anywhere from 10 to 30. I set mine to 30.
* In the Filter bar type network.http.proxy.pipelining. Then, double-click on this line under Preference Name in order to change the value from False to True.
* In the Filter bar type network.dns.disableIPv6. Then, double-click on this line under Preference Name in order to change the value from False to True.
* In the Filter bar type plugin.expose_full_path. Then, double-click on this line under Preference Name in order to change the value from False to True.
* In the Filter bar type network.protocol-handler.external.ms-help. Now, you are going to create a new Preference Name with an Integer Value. To do this, right-click on this line under Preference Name and select New, then Integer. In the New Integer value box type in nglayout.initialpaint.delay and click OK. Then in the Enter Integer value box type 0 (that’s a zero) and click OK.
* In the Filter bar again type network.protocol-handler.external.ms-help. Now, you are going to create another new Preference Name with an Integer Value. To do this, right-click on this line under Preference Name and select New, then Integer. In the New Integer value box type in content.notify.backoffcount and click OK. Then in the Enter Integer value box type 5 and click OK.
* In the Filter bar again type network.protocol-handler.external.ms-help. Now, you are going to create another new Preference Name with an Integer Value. To do this, right-click on this line under Preference Name and select New, then Integer. In the New Integer value box type in ui.submenuDelay and click OK. Then in the Enter Integer value box type 0 (that’s a zero) and click OK.
Now, close your web browser and restart it. You’ll see how much faster web pages are loading. I sure
01010101 G.I.G hacker 01010101
www.gighackers.blogspot.com
2. Pull down the "Tools" menu of Internet Explorer.
3. Select "Internet Options."
4. The "General" tab appears.
5. You'll see the "Home page" box at the top.
6. Click the "Use Current" button in that box.
7. Click "OK."
8. Close and open Internet Explorer. You should see your new home page.
Firefox for any operating systemChanging your home page in Firefox is easy. Just follow these steps:
1. Browse normally to the web page you want as your home page.
2. Pull down the "Tools" menu of Firefox.
3. Select "Options."
4. Click on the "General" tab, if it is not the first to appear.
5. You'll see the "Home Page" box at the top.
6. Click the "Use Current Page" button in that box.
7. Click "OK."
8. Close and open Firefox. You should see your new home page.
For Google chrome try this.
http://support.google.com/chrome/bin/answer.py?hl=en&answer=95314
Thank you.
