Posted on Feb 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I was told my mic had a 10 year warrentee - Sennheiser Audio Players & Recorders
Anonymous
Level 2:
Sergeant:
  • Expert 298 Answers
  • Posted on Feb 23, 2011
Anonymous
Expert
Level 2:
Sergeant:
Answers
298
Questions
Helped
115291
Points
566
Sennheiser normally have a 2 year warranty on their products.
You can check your specific model at their website - navigate to the model number and click on download user instructions pdf (top right of page)
http://www.sennheiser.co.uk/uk/home_en.nsf/root/private_microphones
How do i turn my internal microhone on a HP paviliong6 -windows 7 updated to windows 10
the reasons is , youR unstated PC does not support w10, best guess on model full not told.
G6 means Gen 6
Pavillion name is used for desktops and laptops but is LAP. but you told internal word so is LAP.
internal = LAPTOP
pav G6.(no sub model told)
there are vast reasons but w10 killed the mic, tops the list. (the OEM support pages answer this)
why not ask at Hp.com real forum and not here.?
I can no guess what model PC you have.
But here is guess only as 1 example, of 1 PC.
the 2041si
see the DASH, see the super important number
BTW: at hp.com tell them the service tag numbers
and all this happens in 5 seconds (driver) found.
HP Pavilion g6-2041si Notebook PC (windows 8 max)if the sound drive is a mess load the wrong one for w8>?
in windows 8 to w10 compatibility mode. first.
cross fingers doing that as all must do, on older PC.
that is cause #1 , wrong OS loaded. not asking HP first.
2:
other reasons lots.
device manager shows it failing, fix it ask now.
to fix that get the right driver from HP.com
3:
mic is muted. in w10.
there can be other apps that use mic and the app is set muted.
tricky that no?
4: external cures, even BETTER !!!
or buy nice USB mic , amazing quality there.
or buy USB headphone/boom mic in one. and wow skype heaven.
NO PC told at all G6 tells me zero;
HP marked vast PC models G6. and are NOT The same PC.
good luck and CHEERS
How do I get my Dell De6410 to recognize external microphones
connected how, 3.5mm jack (mic port) or USB mic like mine
i can connect both
and then in the mixer sound windows
click on mic input I want
control panel
sound
recording tab , pick one./
if usb fails try all USB ports.
my usb mic real fancy with built in sound effects even echo and more.
there are like a gazillion types of mics now, boom mics and gee and endless list. even gun mics. to avoid noise , near by.
no mic told, at all
no OS told ,windows guessed
a usb mic also must show up in device manager or will fail
I have a motherboard biostar G31-M7 TE , the front audio connector is : 1. Mic Left in , 2. Ground , 3. Mic Right in , 4. GPIO , 5. Right line in , 6. Jack Sense , 7.Front Sense , 8. no pin , 9. Left line...
Intel G31 is tech, from year. Aug 2008
learn audio drivers come from only 2 places
the OS PnP servers at microsoft
or from oEM BIOSTAR.
the motherboard is DIY grade and that means the manual covers all that. did you RTM the manual first.
no PC case told. at all, and mixing OEM cases with mobo will fail here, for those jacks front not any kind of industry standard at all
the rear work so why not use those?
those front cables are custom, jack sense only works on the maker of the CASE not told the OEM case and model not told by you.
dell,hp or who?
worse yet that mobo has no front panel feature at all
proof here.
https://manualsbrain.com/en/manuals/807036/?page=14
just use rear, abondon old OEM case front audio.
or buy a real DYI case what large slow quiet fans and win.
My wallet has a dark grease .how can I take off? ill tried soap but the still has the grease. I bought my wallet the last weekend my question is that can I return the wallet? they told me that I have...
Hello dear
I guess the walet although in warrentee but warrentee is valid fr if the product stitching is opened or leather is shwing shades after few days but if its your fault i.e. like grease drop etc then you should not claim warrentee....
Well dear do not worry try these steps, may be this could help you.
1. Apply a talcum powder or cornstarch to the affected area, then brush away. If the stain is heavy or old, proceed to next Step.
2. Place stain facedown on paper towels. Blot back of stain with a dry-cleaning solvent. Replace paper towels as they soak up the stain.
OR
3. Wash in the hottest water that is safe for your leather.
Best Regards
( Don't Forget to rate, Please)
Our 55 cup coffee pot broke, it has a one year warrentee, it is from JC Penny's home collection. How do I go about getting it replaced or fixed.
Go to where you get your 55 cup coffee pot and have their assistance regarding waranty replacement or
fixing it. Send your e-mail comments
Washer < 1 year old. Jet dry will not go in
as ur machine is still under warrenty u should go in touch with GE and have thos problem solved free of charge....
2answers
I have a 2007 focus, and about 20,000 miles the rear drum brakes started squealing. My Ford mechanic said this is common and offered to fix it for about $200. Is there a recall or TSB from Ford Company...
I was once told that the squeeling comes form the edges of the brakle pads vibrating when you stop. To fix it, remove the drum and sand off the edges of the brake pad. If you want to get serious, taper the edges of the pads with a grinder. Some Brake pads and shoes come tapered right out of the box. Be conservative only remove a little bit of material.
Does not read any disk on ps3
time for a replacement drive
ps3 40 gb are going bad alot, you have a 1 year warrentee on the ps3 from sony, from the day you purchased it. i hope you have the reciept, call sony and request a repair box or RMA box if its under warrentee, usually take about 2 weeks to get back, make sure you remove and games CD from it before shipping.
good luck
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
Top Sennheiser Audio Players & Recorders Experts
 Grubhead
Grubhead
john h
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
