You probably just need a carburetor adjustment. At half-choke the engine is getting an overly rich fuel mixture. This is normal procedure during warm up, but after a couple of minutes, a leaner mixture is needed. That is where adjusting the carburetor comes in. It probably has a Zama or Rueiing carburetor. I use small automotive type wire connectors (plastic) and lightly tap them onto the irregular heads of the adjusting screws. These are marke L and H respectively on the carburetor. The L screw is always closest to the engine. Here is how to make the proper adjustments. If this doesn't work then a good cleaning and/or rebuild of the carb will be needed. They periodically need this done at any rate after a couple years or so. Please view this:
http://www.zamacarb.com/tipspage.html
