This means the component inside the unit which is saddled with the distribution of power has failed. Due to the failure it is not passing power round as it is supposed to. This could have been caused likely by a power surge into the unit or improper connection inside the unit.
Usually these systems are made such that when these things happen only a little fuse gets spoilt such that the other main components dont get spoilt so all you have to do is locate that particular fuse which is burnt.
If you dont have the technical expertise it is best to refer to an expert to open up the unit and get the fuse replaced. And also sort out the faulty wires in the case of bypassing or bridging wires in the case of an improper connection.
Hope this solution has been helpful?
