If it's a panasonic repair or replace power supply you should listen carefully of the number of clicks from relays.when you first push power,two clicks followed by a third within 3 to four seconds.if you don not hear the third :) its the power supply.hope this helps
Hisense only has 10 blink codes, on most brands they're helpful but not as much on Hisense, in 9 out of 10 sets it turns out being backlights, we've had sets before in our shop where an image wasn't visible, but it still turned out being bad lamp strips. Power boards are a bit different on Hisense sets as loss of backlights can put the set in sleep mode leaving only the standby voltage. Best way to troubleshoot the set would be with a backlight tester
Congratz. You bricked it. Messing with fimware is mortal for electronic equipment. Maybe an authorized Sony repair service can help you, most probably not.
Good day.
First, Have your tv 's circuitry be resoldered. this might be a case of loose contacts particularly along the crt circuitry. the longer you operate the unit at this condition, the faster you are counting the possibility of shortening the lifespan of your tube. 9 years is quite a young age for a unit which has an average of 18years.
Its sort of silly, but my father got behind the tv and smacked it. The error message went away, and the tv is working fine now. It wasn't easy for him to get behind it though, it's rather tall and weighs 234lbs. I did manage to find a pdf file of the repair manual for this model at Techlore.com.
KV32hs500 tv won't turn on. Standby light blinks 7 times, stops and then 7 more times, etc.. The tv will usually come on after about 2 hours or so of being off. Plays fine when on but once it gets turned off the problem happens again. Any suggestions? T.V. is 5 years old.
I have a similar problem . mine blinks 6 times or 7 sometimes also,and comes on with sound ,no picture for about 2 seconds then shuts off. Anything?
make and model?
