Syntax Olevia 532H 32 in. LCD HDTV Logo
Posted on Feb 13, 2011
Does ovelia model 532 B-12 come with built in tuner.
Anonymous
Level 1:
New Friend:
  • Contributor 13 Answers
  • Posted on Mar 05, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
13
Questions
0
Helped
5408
Points
14
I purchased a 532-b12 several years ago - it includes both an analog and digital tuner.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 07, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
523
Points
Olivia model, #532-B12 FMI-032000EGS30. Light is on unit, but no picture or indication of any power on set?
Hello, I was wondering what board is responsible for the function of switching channels.
Depending largely on the age of the TV, the location of the TV tuner varies. An older analog TV tapping a digital signal does so with an external DTV converter box. For cable and satellite subscribers, there is a a set top box. Most TVs purchased after March 2007 have built-in digital tuners. Look on the front and back of the TV for a marking that indicates a digital tuner. It may say ATSC, DTV, HDTV, Digital Ready, HD Ready, Digital Tuner, Digital Receiver, Digital Tuner Built-in or Integrated Digital Tuner. Any of these is an indication that the TV has a built-in digital tuner. You may have to go to the manufacturer's site to determine such specifications. If you are having a problem with a tv switching channels, remedies may be rather specific and you might try googling for a specific model while including the problem in a simple phrase.
1helpful
Does a hitachi 42 inch need a converter box to be able to watch regular tv
Which model do you have? The ATSC tuners were required in 42" TVs starting in the middle of 2005. Some Hitachi 42" TVs built before that date have an ATSC tuner but other models do not. The ones that didn't were usually called HD-ready TVs. For those models, you need a set-top box to receive OTA signals (except for some low power stations that continue to broadcast an analog signal).
If you provide your model number, I'll try to confirm the tuner information. If you look at the model information plaque on the back of the TV, you will see some information about when the unit was manufactured. If it was built in 2006 or later, you can be sure that the unit has a digital tuner.
I hope this helps.
Does my Insigna Tv Model number NSFTV27, serial number 065260705675 have a built in digital tuner? Also, what kind of antenna should I get for this model?
Hello
Your Insigina TV has no built in digital tuner. It has VHF/UHF/CABLE IN tuner. It is not a digital one. OK.
Does my model have a built in tuner please Sanyo   LCD32xR8DA  television as the manual was lost this is all the info i have .    flat panel television
Yes your unit has a built in tuner:
Tuner Tuner Type HD Digital
Included Tuner Style Inbuilt
Pal Reception System B/G check this for more info
Does this model have a built-in QAM tuner?
Yes it does.
  • Includes built-in ATSC/QAM/NTSC tuner for off-air HDTV and SD (standard-definition) reception
  • Accepts high-definition 1080i, 720p, and 480p signals from DTV set-top receivers and progressive-scan DVD players
  • Side-panel A/V hookups and controls allow easy connection with a camcorder, gaming console, or other device
  • 2helpful
    Is my Toshiba TV digital or analog?
    if there is a label on the tv stating any of these words “Integrated Digital Tuner,” “Digital Tuner Built-In,” “Digital Receiver,” or “Digital Tuner,” “DTV,” “ATSC,” or “HDTV” then yes
    if they say “Digital Monitor” or “HDTV Monitor,” or as “Digital Ready” or “HDTV Ready" then no
    Does model Polaroid TTM-2401 TV have a built in digital tuner?
    You TV does not have a built in digital tuner, so is not HD compatible.
    Digital TV
    It does have a tuner built into it.
    It is not a hd or digital tuner.
    manual
    <A href="http://www.uwsp.edu/cps/facilities/classroom/manuals/VCR/PVD4752.PDF">http://www.uwsp.edu/cps/facilities/classroom/
    manuals/VCR/PVD4752.PDF</a>
    Top Syntax Televison & Video Experts
    Grand Canyon Tech
    Grand Canyon Tech
     Grubhead
    Grubhead
    Are you a Syntax Televison and Video Expert? Answer questions, earn points and help others
