I bought and install the U are u biometric finger print scanner to be used for JAMB utme examination in Nigeria. when ever i connect to the site www.jamb.org.ng to capture finger print and upload, the site tells me that the scanner is not connected whereas it is.
please help
Thanks
1. This kind of problem happens when you re-formatted your computer 2. You just install your scanner this year
3. You did not have biometric license installed on your computer, this license makes your scanner authenticated over the internet when you are visiting jamb website, if you are in Nigeria. It also comes with Jamb Biometrics Capture Software, .Net Framework, Java Framework and other software that will make your experience very simple after installing.
The way you out, you need BIOMETRIC LICENSE, if you are operating JAMB BUSINESS.
Hope this help you, if you need more clarification you can email me on biometricmasters2000-jamb at yahoo.com or phone me on 08132829820
3. You
software that will make your experience very simple after installing. 4. If, you have the license, then you did not supply the 16 digit security code for the scanner.
Ade, if u r using your scanner on jamb website. You will need a - You to provide 16 characters security key.- biometric license and - JAMB Biometrics Capture/uploader software. * The biometric license gives you authentication while the JAMB Biometrics Capture software allows you to capture thumb-print even when there is no internet connection(offline) and automatically upload them to server when the internet is back. You can thumb-print as many student as you can (I have seen a client who thumb-printed as many as 2000 in 3days). We give technical advise and we have several license in stock to give away. While not call us today, if the problem is still persisting. Call 08132829820 or email us on [email protected]
Check to see if more than 1 biometric scanner is enabled @ device manager>Disabled all leaving only 1 supported finger print scanner enabled. This error is most common if you have on-board or integrated biometric Reader...Try this 1st;still got answers if this doesn't work but it's been proved as remedy for this particular error :) Thanks The Rule is:Help others without charge :)
HTML clipboard
2. You just install your scanner this year for the first time.
key installed on your computer, this license makes your scanner authenticated over
for the scanner.
for the scanner.
HTML clipboard
for the scanner.
3. You
3. You
for the scanner.
