SOURCE: bugaboo raincover does not fit
I couldn't get my raincover to fit....but then flipped it around and it fit!!! I had to see the instruction cd again to get it to fit...maybe they gave you the wrong raincover twice....but try this!
SOURCE: lost instructions
CONTACT BUGABOO
PHONE: 1-800-460-2922
E MAIL: [email protected]
WEB SITE: WWW.BUGABOO.COM
SOURCE: Can I use the cameleon or frog seat frame on a gecko chasis?
Hello. My recommendation is to have your local tailor or seamstress make a new one using the old one as a pattern. Getting into replacing the seat frame will be a lot more complicated
SOURCE: Can i put a bugaboo frog carrycot on a gecko
I WOULD TRY A CAMELEON CARRYCOT FABRIC, THIS IS SLIGHTLY LARGER THAN THE FROG AND MAY GIVE THE LEE WAY THAT YOU NEED :)
SOURCE: Bugaboo Gecko Collasped Chassis won't open.
To open the Gecko, follow the steps below:
Stand behind the folded stroller, ensuring the handle is on the top of the stroller.
Bend down and place your hands on the handle bar, DONT lift the pram, make sure it stays on the floor.
Push the white button on the inside of the left hand side of the handle bar.
Pull both triggers (located inside of the handle bar) toward you and lift the handle up.
Stand up-right, and place your foot onto the bottom of the two axles which you can see in front of you (make sure that you have your foot on the axle which connects the two small swivel wheels).
Whilst you are standing, with your hands on the handle bar and your foot on the axle, push the axle outwards with your foot away from you and slightly upwards. This should open the chassis up-right. Please note that the chassis will appear to be unstable and move, this will stop the minute that you click on your carseat/carrycot or seat unit.
I hope this helps.
