Motorcycles Logo
A
Anonymous Posted on Jan 24, 2011
How does the wiring go to hook the battery back up on a 2010 dyna superglide. harley davidson
Anonymous
Level 3:
Brigadier General:
  • Master 4,565 Answers
  • Posted on Jan 25, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
4565
Questions
0
Helped
2156243
Points
14358
The cable coming from the starter goes to the positive side of the battery. The cable coming from the frame connects to the negative side of the battery. There may be an auxillary power wire. If it's red in color, connect it to the positive side of the battery. If there is a charger pigtail, connect the red lead to the positive lead.
Good Luck
Steve
Harley 2006 Dyna Superglide pipes fit Harley 2005 Ultraglide
No. The head pipes will bolt up to the heads because those mounts are the same, but the rest of the exhaust mounts are different.
2007 Dyna Super Glide FXD, Do I pull the starter out without going into the Primary ? seems you do..
You need to pull primary. Then remove starter gear bolt. Disconnect battery. Then remove 2 starter allen bolts. Disconnect battery off starter and start wire. MOPAR KENNY
2003 harley davidson dyna superglide ignition type
2003 is single fire. If you buy anew tach, it will come with instalation instructions. With a little common sence, it's pretty easy.
Top Harley Davidson Experts
Arnie Burke
Arnie Burke
Sean Wright
Sean Wright
ZJ Limited
ZJ Limited
Are you a Harley Davidson Expert? Answer questions, earn points and help others
