Hello - I have a cooker hood Belling 600CGH model 1Q2HP (444448742) and believe i need a new transformer for the halogen lights - can you advise which transformer I need?
There is a error message there, it indicate a problem with your induction cooker. It cause a defective winding wire or circuit controllers your know induction cooker works similar to the principle of electro magnet induction, it give heat to metal cooking pot. I hope I give you a idea regarding what happen to your unit.
With the greatest respect, the UK have not used DC mains supply since the 1950's. There is no possitive and negative anymore. We use alternating current. The cable fixing that model of cooker must be red/black and earth. I advise you get an electrician to connect it for you.
I have a Bene Casa Pressure electric cooker given as gift but has no instruction book. I need to know how to put pressure on it when I am doing chicken, If any knows it would be appreciated.
That should come with a drawing to cut out, sometimes the box itself will have that on, and one places it on the wall to mark screw holes for fixing. It will run, as it is only a fan and a light buld, from the cooker switched outlet on the cooker point, or a fused outlet from a spur. If you are unsure, get a qualified electrician to wire it in for you!
What you must do is calculate the total power required by the Bosch cooker. Convert it into Amperes and copper cable is roughly 10 Amperes per 1.50mm cable. What size cable feeds you cooker at present? Or Is the maximum power calculated for the old cooker the same or more than the new cooker. If it is and the old cooker was installed by a qualified electrician observing local electricity codes, no problem get it fitted, if not consult a qualified electrician.
Probably the main wire is faulty or the fuse has blown out.open the cooker from below
{find,check the fuse with a continuity tester}do check the main wire with the help of a continuity tester too for any kind of breakage.If there is no continuity or the tester bulb does not light up there is a fault with the component.Replace the wire/Fuse with the same rating or quality and your cooker will surely work
