Hi ,
you phone have have a carive virus ,a virus that sending automatic mms to someone who texting you..you always see the message in you outbox ,right? ..as of now your memory card and phone is infected by the said virus ...here is the solution for your problem ..
1.make sure that you save all your important files ,like numbers in phonebook because it will be deleted
2..turn off your phone
3.unplugged your MEMORY CARD
4..turn on the phone with sim card
5.type *#7370# ,it will asking for locked code
6..enter locked code ,(if not change the default code is 12345)
7.the phone will now reboot ,wait until its done and the virus is gone in your phone..
but there is still virus in the memory card ,if you insert it in the phone the virus will back so you have to reformat the memory card ..you need a card reader ,connect to the computer but save first all your important files then after saving you will now select reformat...
hope it will help you ,thanks for trusting fixya...
Make sure that your mobile GPRS settings are active, if not
activate it.
For Globe subscribers:
For a list of compatible MMS & GPRS handsets, send
NOKIA, ERICSSON or SAMSUNG (depending on your handset model) to 2365.
Note: Regular text messaging charges will apply.
To get your phone's settings, text GO (handset model) to
2951. Example, GO N3650. (For a list of compatible handsets, do as instructed
above)
Note: For Nokia 6220, 6600, and 6820, text GO (handset
model),, 1234 and send to 2951. Make sure to type in the two commas before the
1234 PIN.
Enter 1234 when asked for PIN to save settings.
Send an MMS message for only P5.00 to activate the service.
(or)
just request your service provider for GPRS settings , so that they will send you the settings to be saved, now you can activate and use the Net ans also the MMS service.
Thanks for rating
good luck
