Owner is saying that toilet keeps running.I changed the fill valve and the flaper works fine.
If the flapper base has a nick or debris on the lip of it, water can get by, dropping the level. You might also check the tube attached ti the flapper; if it is cracked, water will also escape through there. Make sure that the water level is not too high above the fill line. If it is, it will overflow the same tube attached do the flapper base.
Less frequently, but a possibility is the adjustment of the chain or flapper float. If the chain is left too long, it can get under the edge of the flapper and keep it from sealing. That's why I like the tupe with a small float attached to the chain. If the chain is too short going to the handle, the flapper may not seat fully. If the flapper chain has a float assist attached to it, the float can sometimes catch on other things in the tank, most noticeably the float lever, if equipped. Speaking of which; if you installed the fill valve type that has a ball float on it, the ball can rub against the side of the tank, the overflow tube, or catch the flapper chain/handle/flapper float. The correction cor this is to reposition the fill valve assembly so the ball has good range of motion.
If all else fails, you can replace the entire tank and guts for about $30. I recently did this for a cracked tank, and got one at Lowe's. It was a generic, and went on an American Standard. Worked fine.
Pull the lid off of the tank and just look for the obvious!
Best regards, --W/D---
