Hi there.see if this link helps you get it sorted.
2002 yamaha raptor and it wont start Google Search
SOURCE: 1986 yamaha fz400 wont start
You need fresh gasoline in it, if it's been idle for two(2) years, you also have to clean everything that your gasoline touches like the tank, fuel filter, fuel line, carburator, before pouring it in. If that wont help you, Have your CDI tested if your plugs wont spark. Also ask for the history of your bike, if it was running before they stopped using it.
SOURCE: YZ 450 STARTING PROBLEM
Hi and welcome to FixYa,
Offhand, the backfire is significant. It indicates that fuel is getting inside the combustion chamber and it further confirms that there is spark. Being the case, it would appear that this is now a timing issue. A couple of ideas to explore:
Good luck and Thank you for using FixYa. Happy Holidays.
SOURCE: 04 yfz 450 wont start with electrical start
i have a 04 yfz 450 quad. the compression ratio like yours is extremely high. ive had my battery go bad and found that another battery other than factory would turn over the engine, but would not start. i paid the 100 dollars for the factory battery and it fired right up. because of the high compression you need a high cranking battery.
SOURCE: where are the recepticles located on a yamaha 2002 v star ?
The transmission uses your engine oil for lubrication. One of the reasons to use a quality motorcycle oil in your bike NOT car oil...Top off your engine oil, (pour in dipstick hole) and have a good ride.....Good luck to you....Tim
SOURCE: Yamaha 2001 Raptor 660, need to clean my carb
Drain and replace the gas with fresh.
Remove the air cleaner and spray carb cleaner into the inlet. Work your throttle a little then put everything back together and try to start it.
