Kenwood KDC-MP335 CD Player Logo
A
Anonymous Posted on Jan 15, 2011
I have a kenwood kdc-3165 and all the wire are not marked can you tell me the wireing digram . what is the ground which one is the constant power and which the ignition power wire
kenw392
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Kenwood Master 2,226 Answers
  • Posted on Jan 17, 2011
kenw392
Kenwood Master
Level 3:
Renaissance:
Answers
2226
Questions
Helped
474512
Points
4986
Black is ground, yellow is constant and red is switched or ignition.
I need a wiring diagram for a kenwood cd receiver kdc-448u
Red..accessory
Yello..constant...battery..
Black..ground..
Blue/yellow ...steering ..
Blue/white..remote..
Blue..antenna..
All speaker wire wuth black..negative..
All solid color is positive
I cant figure out one of the wires on my kenwood car stereo
Hi, red = ingnition power black = ground yellow = constant +12v blue = remote. There should be 8 wires bunched 4 colours & 4 same colours with white stripes. These you will have to experiment with your cars wiring. This is just a eneral rule for most stereo wiring.
Hope it helps.
Wayne
http://techrehab.t35.com
2answers
Need wire diagram 4 kenwood kdc-122
Red wire is switched power (only has power when key is turned), yellow is constant power, black is ground, blue is accessories (e.q. or amp switched power), dual grey, dual blue, dual white and dual other is for speakers, (usually the one with the marking is the positive speaker side). This should help..
I bought a kenwood KDC-BT742U and I'm putting it in my 96 saturn. I connected all the speaker wires and I believe I ran into my problem with the ground wire (black) power wire (red) and a power control...
as far as i know there is no green with a white stripe on kenwoods, unless you are looking at a blue with white, which is an amplifier remote turn on wire. you should have a yellow wire which needs to be connected to a constant power source, as this wire keeps the radio preset and clock from losing memory.
5helpful
I was given a Kenwood KDC-1011S. All wires labled
Yellow is for constant 12v. (Power directly from battery) so it maintains preset stations and clock memory. Red is for Key "on" 12v Power (turns on when ignition key is on) Black is for Chasis Ground. What type of vehicle is it going in? I can get you the corresponding vehicle color as well. Post a comment with make/model & year vehicle. Hope this helps.
2answers
Kenwood KDC-138: Removed Old stereo, installed new KDC-138, I'm getting power to the plug that plugs into the back of the unit & fuse is good. I've tried pushing the reset button. Nothing comes up on...
do you have power at both supplys on the wire harness?( red and yellow) red wire will have power with the key on. Also make sure your ground is hooked up right.
1helpful
2answers
How to install kenwood kdc-x493 with kac-8104d in 1996 honda civic?
very simple on the back of the deck you will have a wire harness
Yellow = constant power supply
Red = Switch power supply
Black = Ground
White = left front speaker +
White /Black stripe = Left Front speaker -
Grey = right front speaker +
Grey /Black Stripe = right front speaker -
Green = left rear speaker +
Green w/ black stripe = left rear speaker -
Purple = right rear speaker +
purple w/ black stripe = right rear speaker -
wires for the honda are,
Constant 12V+ Blue/White Switched 12V+ Yellow/Red Ground Black Left Front (+) Blue Left Front (-) Gray/Black Right Front (+) Red/Green Right Front (-) Brown/Black Rear Speakers 6" x 9" Rear Deck Left Rear (+) Blue/Yellow Left Rear (-) Gray/White Right Rear (+) Red/Yellow Right Rear (-) Brown/White
4helpful
Kenwood kdc-x491 wiring diagram
red, yellow, black/ign constant ground
blue, blue white stripe/rem pwr ant
grays, whites, purples, greens/ front front rear rear
its the same on all headunits except cheap *** wal mart headunits
Kenwood kdc mp-425 plug
i have kenwood wire book i can tell u colers ?
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
