SOURCE: i have a Rockford Fosgate Puch 1000 watt amp "thermal" problem
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
If the voltage remains near or above 12v, disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up without the thermal LED being lit, the wiring needs to be checked. If it still indicates that it's in thermal protection, it needs to be serviced. A local repair shop will be the quickest. Rockford will email you the schematics.
SOURCE: amp only has red thermal light on. some times the
Please review your wiring, both INPUT and OUTPUT
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_aad3edb7dfa380b9
SOURCE: rockford fosgate 3002 thermal light on no sound
Is this powering speakers or subwoofer? If it's the subwoofer you need to make sure the gain is turned up and the sub is set to low pass frequency. Also make sure bass and subwoofer are enabled on the head deck. Make sure the RCA's are hooked up properly at the back of the head deck. If it's the speakers then you may have balance set to front only so your rear speakers aren't making noise.
SOURCE: Rockford Fosgate Punch End CapsEnd Caps
I TAKE IT THAT YOU ARE REQUESTING A SOURCE FOR A PAIR OF ENDCAPS FOR YOUR PUNCH-200IX. IF THIS IS THE CASE, I SUGGEST THAT YOU CHECK EBAY ON A WEEKLY BASIS AS I AM SURE AFTER SOME TIME, YOU WILL SEE A PAIR LISTED. THERE IS ALSO A SELLER ON EBAY THAT HAS MANY OF THE LOGOS FOR THE MANY DIFFERENT MODELS THAT CAN BE PLACED ON ANY OTHER MODEL ENDCAPS FROM THE SAME SERIES (DSM, IX, X2, ETC. LET ME KNOW IF I MISUNDERSTOOD YOUR REQUEST......V
