try to get an cardreader and connect it to the pc by inserting your memmory in it and then format it if it recognises the memmory...othervise its damaged...
mY Dear: First: restore your Phone Settings IF Restart problem not Solved So Secend Option: Please Format Your Phone we can solve this problem but i need you to backup the whole DATA that you have in the phone and perform this reset procedure. *#7370# or *#7780# Default security code is 12345 release some memory then it will b opened your phone or memory card get attack by virus. pls do a format phone and memory card. If Problem Not Solved So Very Best Solution: flash new software install in the phone problem will solved quickly
I had the same problem with an HTC Aspire ( I think that's what it was called :} Anyway I formatted the micro SD card in fat 32 through my laptop using a micro sd to sd adapter and the sd card slot on my laptop. I then stuck the micro sd card back into the HTC and it worked. I heard formatting through another phone works too. Try it and let me know.
use a card reader then insert your external memory to it plug it in to the USB .open the my computer icon then right click your device (memory card) select format..
you can check it with other sim card ,if it remains the same problem ,it may be locked to particular network wont accept any sim card other than the particular network ,you can unlock it and used to other network
1. Purchase a Micro SD card 2. Make sure you have a memory card reader for your pc if not buy one. 3. Plug in your memory card and memory card reader to the pc. 4. Drag music onto your card. 5. Put memory card back in your phone! YOUR DONE!! :)
