You can connect TV RCA outputs to any line input e.g. tape, tuner, CD etc on the Marantz. If your TV doesn't have separate RCA outputs use a 'scart to RCA audio outputs' adaptor... TVs have a standard line output level compatible with most if not all hi-fi.
If your Nokia N93 says Invalid Sim it's locked to network...You need to unlock it from network lock to use with other GSM Network sim card....Find the network,Country it's locked now,get the Unlock code at Mobileunlocksolutions.com/nokia-n93/rs1wp9/ and Unlock it from network lock easily...
It may Because of the Network Lock,.So that it's not reading the Sim,You need to Unlock it,You can get the Unlock code at here http://www.theunlockspot.com/nokia-n93/rs10wp9/ and Unlock it,then You can use any GSM Sim Card in the Mobile...
your new tv probalby has an hdmi output. depeding on how old your jvc system is, iit may or may not have an hdmi input. not to worry, there should be some type of compatible output on the tv to send audio signal to the jvc. first look at the back of the jvc and see whats there. then look at the tv and you should see compatible output on tv and run proper cable to input on jvc. some auxillary audio outputs on the tv are driven by the volume of the tv itself, so make sure to turn the volume on the tv up a llittle to make sure its sending signal. you may have to go into the tv menu and turn the internal tv speakers off so you dont hear them and the jvc. its not a big deal if your hearing both, it just wont be true surrond sound. if it were mine, id turn the tv speakers off.
