Hi, and no. The fan on the outdoor condenser always turns in the same direction on a heat-pump. What changes is what is called the reversing valve located by the compressor. It reveres the flow of freon in the winter on its own, with the help of the control board and thermostat. There is nothing for you to change but putting the thermostat into the heat mode, and the unit will do the rest. Good question though.
Sincerely,
Shastalaker7
A/C, Heating & Refrigeration Contractor
Hi, just checking in with you ? do you understand what I have told you? There is nothing you need to do with the fan as it will always turn in the same direction no mater what time of year. Its the revering valve that switches the flow of freon from the cooling season to the heating, and its all done through the thermostat and defrost control board. Fan will always run in the same direction, nothing for you to change.
Sincerely,
Shastalaker7
