IBM ThinkPad G40 2388 Notebook Logo
Bill Manson Posted on Jan 07, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My AC Adaptor has Karked it. Where can I get a replacement?
Anonymous
Level 3:
Brigadier General:
  • Master 8,909 Answers
  • Posted on Jan 07, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
8909
Questions
Helped
1541883
Points
28391
Ebay is the best choice and price.
Wire my ac jack for my samsung np365e5c
The AC adaptor goes into the AC socket, NOT the computer connection. The Computer connection is DC and comes from the DC side of the Adaptor. If you mean the DC socket has broken, then you need someone to replace it inside the computer.
If the AC adaptor has failed, you can buy a replacement ( 19V 3.16A 60W AC Adapter).
See the Manual
http://downloadcenter.samsung.com/content/UM/201408/20140829115137641/Win7_Manual_eng.pdf
I have an acer aspire 5100 and here recently the
Could be a bad battery and/or charger/AC Adaptor/DC Connector. Try to isolate the problem by removing the battery and then plugging the laptop charger in and starting the pc up. It should boot on the AC adapter alone. If it won't boot on the AC adaptor or it flickers and flashes while on the AC adaptor, I would first suspect the AC adaptor or the DC connector on the laptop (try wiggling the power plug at the PC to try and check the connector). If it behaves while on the AC adaptor without the battery present, I would suspect the battery. Either way, you may have to replace something.
My fountain light adaptor,ming an ac adaptor Model#MAO-120500 is no longer working and i need to replace it.
I found in on line for $7.29 free shipping https://www.amazon.com/CNZ-Submersible-Fountain-12-LED-Adapter/dp/B01ENYPFZS
Jul 03, 2012 • Garden
Lenovo laptop(8932) will go into a sleep like mode (you can still see the screen, very dim) when plugged into ac adaptor. Doesn't do it with battery power. Changed system board, power adaptor - no...
Good Day Psmith!
It looks like the AC adaptor is not making the right supply voltage needed for your laptop.
If you have a multi tester, you can test your ac adaptor to see if it has stable 20V voltage output supply needed for the laptop to make it work.
Set your tester to DC range. Plug the ac adaptor to your wall socket. Hold the other end of the ac adaptor (the one you connect to your laptop. Insert the red (positive) lead into the center of the adapter pin, then touch the black (negative) lead to the outside metal part of the pin.
Read the display in your tester. If the adapter is working properly, the meter should read between 19 to 20 volts of the rating. If the adapter is faulty, the meter will read below 18volts.
If that would be the case, I'm afraid you will need to replace your ac adaptor.
You can purchase online a replacement ac adaptor for lenovo 8932.
1. From this site, it costs $34.99 + $8 https://www.ebuybatteries.com/product/models/2_IBM-Lenovo-AC090W008T15_IBM+Lenovo+ThinkPad+R61+8932.htm
2. From this site, it costs $39.95 http://www.eznsmart.com/p-31667-lenovo-thinkpad-r61i-8932-laptop-ac-adapter-replacement-20v-45a-90watt-charger.aspx
Please accept my answer if this is the information you need.
Don't forget to give a four thumbs up rating!
Thank you for asking Fixya.
When i push the power butten, the indicator light flickers, then nothinghappens
Firstly remove the battery and disconnect the A.C adaptor. Press and hold the power button for 30sec and then reconnect them back and check.
Check the port where u connect the A.C adaptor pin if the light is glowing then need to reseat the RAM and the Hard drive of the laptop (Compartments located at the bottom of the laptop)
If still not comming on then Hardware issue take it to local store.
But if the port where u connect the A.C adaptor doesnt have light then
1. check with different wall outlet
2. check if the adaptor is getting warm or not if not then replace it.
3. If yes then better check with different ac adaptor
2helpful
2answers
I have a HP dv7 laptop it does not work with the ac adapter but worked with the battery, whenever it is working with the battery and the ac adapter is connected it shuts down.
Remove the battery and plug the ac adaptor in check wethere the light on the port where you connect the ac adaptor glows or not, if no then check the wethere the ac adaptor is getting warm or not after you plug it in for few minutes if not then ac adaptor has to be replaced.
If the light on the port is glowing then it is likely that the power supply of the notebook has gone bad as it is not able to switch to ac adaptor or the port where you connect the ac adaptor to the notebook has a short circut when the acadaptor pin is connected , better try with a different ac adaptor to be sure wethere the issue is with ac adaptor or the notebook.
My best wishes
Laptop does not work with AC adaptor, does not charge. Mother board issue
You may be able to get a battery charger but its rare.
If you do wish to use the AC adapter, take care with positive and negative. Also the voltage of the battery is actually lower than the AC adapter in order to get charged. I don't know what is going to happen if you do choose to use AC adapter as battery. 75% chance that it will work.
Battery on lap top is not charging
switch off - disconnect ac adaptor - wait 3 seconds - connect ac adaptor - repeat about 20 times.
Is charge light blinking when you connect ac adaptor?
Try reseating battery.
If battery is old (over 2 years) or heavily used then it may need replacing. They only last for 250-500 complete discharges.
1helpful
Lap top problem
Hi
If the AC power light is blinking, try the following steps:
1 Cut off power to the computer by disconnecting the AC adaptor and removing the battery. The error condition will be interrupted, and the AC power light will stop flashing.
2 Put the battery back into the computer. Do not connect the AC adaptor. Try turning the computer on again. If the computer starts normally, the AC adaptor may be
defective and will need to be replaced. If the AC power light starts flashing, remove the battery, and continue with the steps below.
3 Connect the AC adaptor to the computer. Leave the battery out of the computer. Try turning the computer on again. If the computer starts normally, the battery may need charging, may be depleted, or may be defective. Turn the computer on, insert the battery, and then leave the computer running for several hours, which will deliver a slow, steady “trickle-charge” to the battery. Once the battery has been trickle-charged, it may begin working correctly again. If the trickle-charging does not prove effective, consider replacing the battery with a new one.
4 Connect the AC adaptor to a different power outlet, preferably in a different room. If the computer starts normally, there may be a problem with the AC outlet itself, or the voltage level available from it.
5 Verify that the AC adaptor is the correct unit for your computer model. The computer may not be able to start from an AC adaptor that is rated for less current (amperage) than the computer requires, even if the rated voltage is correct, and the plug fits correctly in the DC-IN socket. The labels on the bottom of the computer and the AC adaptor show the specifications for voltage ("V") and current ("A") for each device. The voltage level must match exactly. The amperage rating of the AC adaptor must be equal to or greater than that required by the computer
Regards
Mike
Top IBM Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
