I used an exe patch for mine, i downloaded from a torrent, with the patch you go into programes locate bejeweled and replace the exe file for the new one, worked great for me .
Right click on the D:/Poppack-setup.exe -> Properties = Compatability Tab.
There should be a box that says "Compatibility Mode" that you need to chek, and then select Win95 and hit OK.
Try installing again.
If it still gives the same error, go back to the tab and go lower than the Compatibility Mode box, to Display settings, and chek "Run in 256 colors" and "Disable Visual Themes"
Try again.
If it still wont work, please respond. If it gives a different error at any time or a different problem, please respond.
You may check for a patch for Windows Vista in the Software maker's website ar may revert to compatible version of Windows, if gaming is more important than interface.
