I would like to find out the voltage and amperage of the simpletech 500gb external hard drive, I need to replace the power cord. thanks
alot
greg holland
[email protected]
I believe that you would be ok. Voltage has to be "Spot on." Amperage, however, needs to "meet or exceed." Think of Voltage as pushing something into something. Think of Amperage as pulling something out of something. It won't draw more amps than it needs, even if they are available. Allow me to thank you for including the powerpayless website as until your post I didn't know what voltage I was looking for. Exactly the same thing happened to me with my SimpleTech 1TB. Perhaps we both solved eachother's problems. PS: I'm going to check with Radio Shack for a 12v adaptor with at least 3.5 Amp capacity. They might can beat the $30.00 which is what the above mentioned place gets including shipping.
The output of your adapter is 12volts 1.5amps the outside terminal is negative polarity and your connector looks like this (see below) There are two options of adapter (see below) both will work
Hello.
It sounds like you might have a problem with the power supply.
I have seen MANY external hard drives with failing power supplies.
Take it to the store you purchased it from for a check up, it should still be under warrantee if its only 3 months old.
Good Luck!
Actually the simpletech dosent need power adapters so u dont need to check for adapters and if you are connecting to usb2 port the power should be embaded so just connect the single usb cable not the both if using usb 1 then connect the both usb cable to usb port if u have already done this please try to change the usb cables wich is connecting the hdd and the pc something wrog in the cable for sure
thanks
