These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/ http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electro-medical.blogspot.com/
Solution 1:
If the blower prover switch does not close after the blower starts the control will stop the ignition trial go into lockout. The blower will continue to run. Automatic reset is immediate after the switch closes
Solution 2:
If the blower prover switch opens unexpectedly during operation the control will shut down and attempt to re-light. If the switch does not close after the blower starts the control will go into lockout with the blower running. Automatic reset is immediate after error is corrected
Solution 3:
If the blower prover switch opens during the postpurge cycle (heater is not fir- ing) the control will display the error code. The post-purge cycle will be com- pleted once the blower prover switch close
Regards,
Samy
the code is IF. it stands for ignition failure.
If the control exceeds the maximum number of ignition retries or recycles the heater will shut down and go into lockout. Automatic reset is 60 minutes.
It sounds like the mains sense wire is disconected from the control panel or the run wire is not being cut by the aux contact on the transfer switch.
Is the transfer switch manual or motorised?
You will need to press the F8 key before windows starts to load then disable the auto restart on error. That will allow you to read the error message and someone may be able to guide you. You could also try booting from the XP CD and run the recovery console (if that's an option) once in the recovery console type chkdsk /r to correct any errors & try booting again.
OR
Disable automatic restart on system failure. This should help by allowing time to write down the STOP code properly. Right click on the My Computer icon on the Desktop and select Properties, Advanced, Start-Up and Recovery, System Failure and uncheck box before Automatically Restart.
Do not re-enable automatic restart on system failure until you have resolved the problem. Check for variants of the Stop Error message.
An alternative is to keep pressing the F8 key during Start-Up and select option - Disable automatic restart on system failure.
If you are using a wireless keyboard and the F8 key does not work substitute a wired keyboard and mouse for this exercise only.
The AO mindicates an open prover switch ,, here from Hawward site .
immediate after error is corrected.
reset is immediate after the switch closes.
Take it in & have it scanned, may only be a faulty solenoid or even brake switch may cause code & symptoms. Sooner you get it in, the cheaper it will probably be to repair it
que solucion hay para este proble?
