20 Most Recent
Krups EA8250 Fully Automatic Espresso - Black Questions & Answers
Krups error code 01
I don't have a service manual so I can't say exactly what it means but I had the same error.
I fixed it by clearing out the pressure chamber where the grounds are compressed and the hot water is run through. There was a blockage that made the displacement lever (the little arm that moves spent grounds to the trash container) stuck and not fully able to move out of the path of the plunger.
To do this I recommend using a compressed air can and a long slender object (pipe cleaner is ideal) to scrape out residue in the chamber and around the moving parts.
'Automatic maintenance on the screen = ground coffee ejected
All of these automated coffee machines need regular maintenance. When was it professionally services by the dealer? My 6 machines in an airport environment needed service every 4 months. At home, probably every 12 months. Seals need replacing and moving parts cleaned and lubricated. In my opinion these machines are totally unsuited for home use. So many issues show up on this website and all makes, but Saeco are the worst..
Dolce gusto krups infinissima red light
The blinking yellow-green and solid red light on a coffee machine typically indicate an error or problem with the machine. Without more specific information about the make and model of your coffee machine, it is difficult to say for sure what the problem is. However, here are some common issues that can cause a coffee machine to display these lights:
Blinking yellow-green light: This light may indicate that the machine is in a warm-up or preheat mode.
Solid red light: A solid red light can indicate several different problems, depending on the machine's model and brand. Some common causes of a solid red light include a low water level, a clogged or dirty brew head, or an issue with the machine's heating system.
It is recommended to check the user manual for your coffee machine to determine what the specific light sequence means and how to address the issue. If you don't have the manual, you may be able to find a copy online by searching for the make and model of your machine. If you are unable to resolve the problem, you may need to have the machine serviced by a professional.
