Set your network connections to :MYGLOBE CONNECT or MYGLOBE GPRS Most nokia phone will have the options to choice connection. So choose the aboved setting In Samsung, by default, TM and Globe sim set MYGLOBE INTERNET, just changed it. Mostly Samsung Mobiles settings can be changed here:
Menu-> Games-> More-> Connections -> Advanced -> Set MYGLOBE CONNECT
Then activate your TM GPRS Configuration first!
HOW TO ACTIVATE TM SIM 1. Be sure you have Php1.00 extra load. 2. Then type this format text: GO ,,1234 and send to 2951 3. example: GO NOKIA N70,,1234 and send to 2951
Hi, you should call your network carrier so that they could setup your GPRS settings. They usually send out the configuration straight to your mobile phone.
Contact ur operator and get the settings for the wap, then go to the browser and type the address you want to browse.
GoodLuck =)
nakakapag surf lang po kayo pag activated po ang GPRS ninyo, so globe po automatic na yan,once inilagay ninyo ang sim sa phone,may darating po na text message mula sa nasabing operator,ito po ay ang configuration settings ng GPRS, i-save ninyo lang po at pag humingi ng code, 1234 lng po ang i-enter ninyo,dapat po may load po kayo para makapag surf o makapag internet.
To activate GPRS and MMS on your phone you need to contact your service provider for sending you a configuration file which will set both on your phone, you may contact them by calling on help line or by visiting their customer service.
Good Luck
Here's a quick tip on how to activate your phone's Smart MMS and Smart GPRS settings if you're with the Smart network: Download MMS and GPRS settings from Smart:
To download SMART MMS phone settings:
Key in SET MMS and send to 211.
To download SMART GPRS phone settings:
Key in SET GPRS and send to 211.
Example: If you have a Nokia 6230, that's "SET MMS N6230"
To activate SMART GPRS:
Key in "GPRS ON" and send to "333′
To activate SMART MMS:
Key in "MMS ON" and send to "333′ Note : The configuration settings will be sent to your phone. You will need to select "Save All" to save the settings in the phone. Some MMS and GPRS handsets already have pre-loaded phone settings.
Activation of MMS and GPRS will require a confirmation message from SMART. A message will be sent to the sub once the feature has been activated
Tell them your model number they wil send the GPRS settings.You wil require to provide your information to them to check the mobile belong to you only.
When they send Please save that to your mobile and set as default setting. After setting you can start using the service.
for activating gprs you should contact your service provider.they will send you gprs settings and just by opening it you can activate gprs in your mobnile.
