If data in your hard drive is really important to you, try to look for a similar model hard drive. Then swap the logic board of the good hard drive with the defective hard drive. If the cause of problem is the logic board, then your hard drive should work by now. If you are not that technical, you can ask a technician to do this for you. You can buy a second hand hard disk for a few bucks at ebay.
You can remove the hard drive and connect it to an USB hard drive adapter. Then plug the USB adapter into a working computer's USB port. If this computer detect this as an external storage device and you can open the folders and files then you can backup your data.
If the computer cannot detect the hard drive then the hard drive is faulty.
There are companies that can recover data from faulty hard drives BUT they will cost you an arm and a leg for their services.
Do you have a suggestion for a good USB hard drive adapter? Make and model number would be very helpful!
You can get them on the Internet or at your friendly computer shop. there are several brands available.
You can get the USB hard drive adapter, there is a model that supports IDE and SATA hard drives.
OR
You can get an USB hard drive adapter case which you can install a hard drive in the case and use it as an external hard drive.
i also faced the same issues which you are facing and my friend told me about "ijinni technician" i contacted them at WWW. Ijinni. Com for any issues Just open the website and you can chat with the experts who are Microsoft certified technicians and will fix the issue itself on the spot or u can call them through Skype or contact and for more visit their website as it is very user friendly website. Just click on the chat as the response rate will be very fast from them and they have fixed my issues in no time.
