Some manufacturers wont release their codes. Some universal remotes do have a general code that will either scan for the right one or allow you to check all of them one by one. Though I have a Sylvania which cannot be programmed by universal remotes. You might find the specific TV remote on Ebay. That's what I had to do after my dog ate my remote. Cost me $15.
When are you people going to learn. The only way you will get it to work is to find the same remote that come with the tv, That is what happens when you buy unknown brand (Electronics) Not evan a good universal remote will work on them, Stick to a known brand.Like jvc,sony, toshiba,lg,panasonic. Then you won,t have that problem. If the dog ate your remote,Because you for got to (Feed) it.
Having browsed the user manual I wonder if you plugged in the Sony BDV T57 Home Theatre System while the Polaroid FLM-2632 tv was powered down via the optical cable .
Then powered up the Sony BDV T57 Home Theatre System first and then powered up the Polaroid FLM-2632 tv
Maybe the Polaroid FLM-2632 TV has to detect that the Sony BDV T57 Home Theatre System is connected and powered up when the Polaroid FLM-2632 powers up. To activate its digital audio out ????
The note part about only being available only under HDTV (cable/air) mode. Might be the cause of your hassle also ?
DIRECTLY FROM THE USER MANUAL
source from http://tv.manualsonline.com/manuals/mfg/polaroid/polaroid_flm_flm2632.html
" ? Connecting to Audio Receiver:
Use an audio cable to connect the audio receiver's audio LINE IN jacks to LCD TV's
AUDIO OUT jacks. ? Connecting to Digital 5.1 Sound System:
METHOD A:
Use an optical cable to connect the audio amplifier's OPTICAL IN jacks to LCD TV's
OPTICAL OUT jacks.
METHOD B:
Use a coaxial cable to connect the audio amplifier's COAXIAL IN jacks to LCD TV's
COAXIAL OUT jacks. Note: Above mentioned function is only available under HDTV (cable/air) mode.
? Connect all AC power sources, before turning on the power switch of the LCD TV or
other connected equipment.
? Press the button on the remote to turn on the LCD TV."
press intreactive on sky remote move down to sky costomer service press select then move down to program remote ( 5 ) you will need make ( lg ) and model number of tv then follow on screen instructions
hope this helps
You probably have too much power running to your power strip that you probably have your xbox, playstation, tv and home theatre system plugged into, try using seperate wall outlets for your tv and home theatre system
