Blu Ray player turns on, displays "Welcome on the screen. After disc is inserted,...
(More)
Blu Ray player turns on, displays "Welcome on the screen. After disc is inserted, "Wait" appears on the the screen and then it freezes. What is wrong?
The voice output or sound is not sychronized with the actors or action. It is delayed by a few...
(More)
The voice output or sound is not sychronized with the actors or action. It is delayed by a few seconds. Actor's mouths are moving and the voice comes a few seconds later, very annoying. Please give a solution, thanks.
hi, i have a sony BDP-S350 bluray player hooked up to a sony reciever (HT SF2300). The player plays...
(More)
hi, i have a sony BDP-S350 bluray player hooked up to a sony reciever (HT SF2300). The player plays dvd's and blurays but sometimes refuses to play either. Switching off the receiver and player, then back on I get the blu-ray disc blue homescreen but then does not go to the set up home page when no disc is in there. Instead it just flickers and no signal seems to come from the player. I have tried: 1) Resetting to factory settings (when the setup screen did appear) 2) Turning off receiver and player- multiple times. Any ideas? thanks ps i think receiver is fine as i do not have any issues with the xbox
Hi there. I need a Blu Ray player with a function to auto repeat a movie - so it plays again and...
(More)
Hi there. I need a Blu Ray player with a function to auto repeat a movie - so it plays again and again. Do you know if this function exists on any players?
My Sony bdp-s350 blu ray player frozen . So I turned it off & now the player doesn't...
(More)
My Sony bdp-s350 blu ray player frozen . So I turned it off & now the player doesn't recognise any discs, it says "no disc", and only the eject tray works. Any ideas?
My Sony bdp-s350 blu ray player froze with no keys working. So I turned it of at the mains &...
(More)
My Sony bdp-s350 blu ray player froze with no keys working. So I turned it of at the mains & now the player doesn't recognise any discs only the eject tray works. Any ideas?
When you get no disk error, that is usually because of a problem with the
optical laser lens that is dirty, faulty or opaque, and will...
written by ginko
To reset the recorder to factory defaults as if it was just removed from the box - leave the recorder on then press and hold the channel up and down...
written by xmarine2847
You can help other;s and maybe they will help you. This can be done by uploading a copy of you user manual and any service information for the...
written by stoneheaded
My LG DVD recorder was unreliable when recording TV broadcasts to "standard" DVD disks. Frequently it would begin recording a show and then...
written by MateusDIY
You should always read the owners manual to familiarize, yourself with the operations of the unit. This will solve a lot of simple operation problems...
1)just open the player 2)remove the rubber belt connecting the dc motor 3)you
can open the disc tray now 4)if there are any dust particles or...
written by dileep007
It is always suggested that you use or buy a cd or dvd cleaner with it's cleaning solution, but I have discovered something that works just as well if...
written by BobbyR1234
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
