Heating & Cooling Logo
A
Anonymous Posted on Dec 21, 2010
Where to find an installation manual for a vulcan compact 90 hot air furnace. Thanks
R Subramaniyam Iyer
Level 3:
  • Master 2,133 Answers
  • Posted on Dec 21, 2010
R Subramaniyam Iyer
Master
Level 3:
Answers
2133
Questions
Helped
953467
Points
6173
You can get it from:
SERVICEMANUALS @ COST www.mauritron.com Manuals at free download:
homeappliance.manualsonline.com/manuals/.../lg_air_conditioner_product_list.html Helpful?
What is the star energy rating of a Vulcan gas wall furnace series 22 (old unit)
Likely too old for an Energy Star Rating.
https://www.google.com/search?q=Vulcan+gas+wall+furnace+series+22+energy+rating
What is the efficiency of a gas wall furnace?
Wall Furnace Energy Efficiency Ratings
Today's wall furnaces are often rated at 80 to 90 percent annual fuel utilization efficiency (AFUE).Jan 26, 2021
Everything You Need to Know About a Wall Furnace - Family Handyman
I have a Vulcan Compact 60 1982 model
No manual, no service manual. It is 40 years old from before the days of the Internet.
https://www.google.com/search?q=Vulcan+Compact+60+manual
1helpful
My old vulcan inbuilt gas furnace now has to be run at max fan and gas to get it to heat - can you suggest what might be the problem and how to fix?? Thanks JH
Does it have good air flow? Air Filter not clogged, fan spins full speed? Lack of air flow, volume, can trip on overheating firebox.
Vulcan compact 90 not working properly
Is this a gas heater or electric heater?
Where is the pilot on the york diamond 90 furnace
there is no standing pilot on your 90% AFUE furnace this is a hot surface ignition
1helpful
I have outside Goodman-Janitrol furnace and air unit and
two things to try first to get you pointed in the right direction. First disconnect the R or RH wire from the T-Stat. If the furnace turns off (Stops firing w/ fan to turn offabout 90 sec. later) then you more than likely have a bad Thermistat. If it continues to run Pull the R wire from the Furnace circuit board. put door back on furnace if it stops you have a short in the wire. Still Running? Most likely a bad curcuit board. Hope this helps.
5helpful
Hi there, I have a Vulcan Gas Wall Furnace Heater 26.4. Would you please tell me where I can get manual book or how to use it. Thanks! Paul
Hi
Please see this link to view/download the manual fro your heater---
Vulcan Gas Wall Furnance Heater
Please accept this solution and ask for any assistance.
Thanks
Rylee
1helpful
Furnace stops before set temp is reached. continously cycles like this Therm ok, tested, bypased with same effect.
Short cycling, could be because of gas pressure, drain issues from inducer and exchanger (if 90% plus furnace), auxilary limit getting to hot (dirty filters, obstruction, dirty coil), or your flame sensor is failing. Does the furnace lock out? or does it just cycle on and off? If it does how often? Thanks
2answers
Vulcan gas wall furnace keeps turning off, and has err f1 on the control panel. Any suggestions? It is Sunday afternoon and about 8 degrees!
No idea what the problem is but - We have a manual vulcan gas wall furnace about 3yrs old and it has always been switching off since installed which is a real bummer on cold days. We had it checked out whilst under warranty but the technician did not fix the problem. Im not sure if it has anything to do with the gas supply but seems more of a product fault. Lucky weve got a combustion stove as well!
I have a gmpn-80 janitrol 90% eff gas furnace,it is only 15 months old,my condisation tray is melting and cracked do to heat in which case leaks water all over....why would this be happening?
Most likely the cause is that the furnace is firing too hot. When a furnace is installed and set up, the manifold gas pressure and fan speed has to be set by the technician so that the temperature rise through the furnace is a maximum of 50 deg F (i.e. if air enters the furnace at 68 deg F it come out no hotter than 118). The target temperature rise on any gas furnace is anywhere between 30 and 50 deg F. If the furnace runs too hot, either the manifold gas pressure must be turned down or the fan speed must be turned up to keep in this range.
Top Heating & Cooling Experts
Paul Carew
john h
