Please help, I have this ducted heating in my house and it is working fine until 3 days ago. I can still turn it on but it will turns itself because does not work.
Is this a gas heater or electric heater?
Posted on Sep 09, 2016
Testimonial: "Gas heater with 9 floor outlet around the house"
Check your thermostat and make sure it's not tripping of there. So, the burner comes on to heat up the exchanger then a minute or two later your fan should come on, correct? How long after the indoor fan turns on does the unit shut down?
Hi Michael, this id Vulcan Compact 90 gas heater, it lights up normal, but it shut down after 1 to 2 minute because fan not activated (for safety reason). many thanks.
Hi Michael, I am not an expert and I will try to find out where the thermostat located and get back to you. I am may be able to upload some images of the unit for you as well.
It sounds like you combustion chamber temp switch has failed. It should heat up the combustion chamber then when it gets to a certain temperature, it should close and turn your fan on. It sounds like it's not closing and then the heater turns off on excessive heat high limit switch. Your going to have to locate the bad switch and replace it. Sorry it took so long to respond, I was out of the country
Apr 09, 2016 | Vulcan Heating & Cooling
Oct 10, 2014 | Kenmore Dryers
Jul 01, 2017 | Vulcan Heating & Cooling
Jun 11, 2011 | Heating & Cooling
Nov 04, 2009 | Vulcan AUW230A Heater
Jun 05, 2009 | Kenmore Elite HE4 Electric Dryer
Jan 27, 2009 | Mastercool 67471 Evaporative Cooler Air...
378 people viewed this question
Gas ducted heater. Burns OK but turns off itself when fan starting in 1 to 2 minutes.
Thanks Michael for your reply, I will need to go on to Google again to first find out what it looks like and replace it if parts still available on the market. Thanks again. David
