headset icon comes on w/out bluetooth being activated and doesn't allow you to hear through the handset unless you put it on speakerheadset icon comes on w/out bluetooth being activated and doesn't allow you to hear through the handset unless you put it on speaker
You can't post conmments that contain an email address.
I am happy to tell you that THERE IS ANSWER:
In normal time mode press S, hold it, then then press D to activate (or press D again to deactivate) the alarm. You will see the symbol of Bell (above the seconds) appear (when alarm is activated) and the bell symbol will disappear (when the alarm is deactivated). Now if you FIRST press and hold D and then press S it will do the same thing (activate or deactivate the alarm). So D then S, or S then D will do the same thing for activation or deactivation of the alarm. BUT, IF YOU HEAR A BEEP (chime) SOUND when you activate or deactivate the alarm, then you actually ALSO ACTIVATED THE HOURLY CHIME!
BUT if you DO NOT HEAR THE BEEP (chime) when you activate or deactivate the alarm, then the Hourly Chime is OFF!
So (in normal time mode) try it both ways: first holding D and then pressing S, or first holding S and then pressing D (one of these will activate or deactivate the alarm WITHOUT MAKING A BEEP (chime) sound - USE THAT SEQUENCE TO DEACTIVATE THE HOURLY CHIME.
I hope this is helpful!
this occurs whenthe user is notwalkingon the belt to disablethis feature you mustpress the option "select workouts" inthe lower right cornerpresslife fitnesslogo, when themenuappearsin maintenance mode select the optionuser sensoranddesactivate thenexit themenuand ready
Sounds like your panel is on its last legs so to speak.
Might be time to look into replacing the panel. Running a high contrast can lead to a shorter panel life which may cause the occurence of dead pixels.
The headset icon always appear in my nokia n70 and cannot remove and when i connect my headset ... it doesn't work . with or without headset the headset icon always appear in my screen .
I know if you use a DS stylus on a DS lite it will mess up the touch screan i dont know what DS you have though and your not suppose to touch the top screan with the stylus. Try reading the DS manual I don't know what to do...
Hi sony with line is a verticle ic la7838 is one of the verticle ics that go in some sony . or cold solder joints on ic if you tap it and picture come back
it should be "0000", i have also a logitech wireless (bought in france)
the only "system" button is "volume up"
press 10s to pair
press 5s to activate a bt connection
press 3s to desactivate the headset
