there is a relay that latches on when you push the start button .. that relay is released by the "door open" switch .. i would suspect that the "door open" switch is bad .. thats usually a button that is pushed in when the door is closed ..
When you press the start button you complete a circuit bringing the juice into your dryer to run the motor the igniter or heating elements and what ever else goes whee when your dryer is drying. So if you press the button to complete the circuit then when you let go of the button it would stand to reason that it break that flow and shut it all down. However in a dryer there is something of a centrifugal switch that kicks in and keeps that circuit open and flowing with juice once the drum begins to turn and you let go of the button. That's why in a normal situation if you don't hold the button down long enough the dryer will cut right back off or if you open the door to the dryer to throw something in and close it before it quits turning it will stay running. Sounds like you could add this centrifugal switch to the list of possible culprits in this mystery. O7OUT
My Hotpoint dryer is seven years old and did the exact same thing. When I got over the anger and the thought of spending 4 or 5 hundred dollars to replace it I started messing with it. I finally decided that since it buzzed when I tried to start it there was current there. The only other thing it could be was the drying cycle knob. I held the start knob and let it buzz while I slowly turned the dryer cycle knob to the right. As I turned through each cycle it would hit "off" and the buzzing would stop and then resume as I moved past the "off " setting. On the third trip around the dryer "started" and has been working since. Maybe something got out of kilter. Apparently the problem was in the knob that controls the drying cycles.
The timer is bad. It is located behind the knobs and can be replaced really easily. The price for a new timer is about 35 dollars. If this helped please rate
I have whirlpool dryer, when i push the start button it will start but only stay on for part of the drying time. no the start button make noise when push and after keep trying it stop.
IF YOU MEAN THAT THE DRYER STARTS BACK UP WHEN YOU CLOSE THE DOOR, THE PUSH TO START SWITCH IS SHORTED. CHECK TO SEE IF THE PUSH TO START BUTTON IS STUCK PRESSED IN AND NOT SPRINGING BACK OUT.
IF IT IS STUCK, TRY WD-40 TO LOOSTEN IT. OTHERWISE, REPLACE THE SWITCH.
IF THE DRYER KEEPS RUNNING WHEN YOU "OPEN" THE DOOR, THE DOOR SWITCH IS SHORTED. REPLACE THE DOOR SWITCH.
The push-to-start switch is the easiest and cheapest to replace. You can check it by starting the machine then, unplug it, remove one of the wires from the switch, then plug dryer back up. Dryer should not start. If your model has an even heat board and two relays under the console, your problem could be with them if switch is not bad. Reply back if you need to know how to check them.
