Get FREE Standard Shipping on orders of $100 or more.
Details
Range: Gas burner won't spark or ignite
A surface burner igniter switch and a spark module activate the spark electrode when a burner is turned to the "Lite" position on a gas range's cooktop. If the surface burner switch, spark module or wiring in that circuit fails, the spark electrode won't work, and as a result the gas burner won't light. If those components work but the electrode won't spark, the problem could be that the spark electrode is coated with spilled food of is bent or broken. In addition, the electrode won't spark or ignite the burner properly if the ceramic insulation sleeve below the tip of the electrode is cracked or broken. If the gas burner isn't lighting, these repairs may help.
Range 101
See all articles
These repairs may help solve your problem:
Replace the spark igniter electrode
The spark igniter electrode-also called the surface burner igniter-is an insulated electrode that provides an ignition spark to light a surface gas burner. It sparks and makes a ticking sound when the burner switch is turned to the Lite position. Replace the spark ignition electrode if it fails to spark or if the ceramic insulation sleeve is cracked or chipped.
How to Replace a Spark Igniter Electrode in a Gas Range
Find This Part
Replace the surface spark module
The surface spark module is in the ignition circuit for the gas surface burners. When a surface burner control knob is turned to the "Lite" position, it provides voltage to the spark electrodes on the gas surface burners. If the surface spark module fails to provide the electrodes with voltage, then it should be replaced.
Find This Part
Replace the spark igniter switch
The igniter switch is an electrical switch on the stem of the gas surface burner control valve. This switch completes a circuit to the surface burner spark module, causing the burner igniters to spark when the burner switch is turned to the Lite position. Replace the burner igniter switch if the burners don't spark when you turn the burner control knob to the Lite position or if igniters spark constantly even when the burner knobs are in the Off position.
Do you have access to the area of the igniter and s it clean and free of rust and debris? How about the distance from the igniter tip to burner hole ( jet)? Is it the same as the other burners and is the spark the same intensity as the other igniters?
the distance is the same and 1 of the burners works occasionally....i am not sure if the spark is as intense on the failing burners...
