Yes some water pumps will start to leak when they are going out. Hope this helps.
Sounds like the radiator is OK...if you cannot see any visible leaks...if you have inspected upper and lower radiator hoses and connections...it could be the water pump...however you should be able to see some antifreeze around the water pump pulley...changing the water pump on your Oldsmobile is not a major job...you do not have to remove any motor mounts to do this...only if your serpentine belt is worn and needs replacement...your Olds will require the removal of the upper motor mount in order to change the serpentine belt...sounds like you are on the right track...:)
