Sony Ericsson W200i Cellular Phone Logo
Prem Ranjan Posted on Dec 07, 2010
My joystick is not working Can i choose radio button like O manage call O divert call from the list using pad
Anonymous
Level 1:
New Friend:
  • Contributor 14 Answers
  • Posted on Dec 07, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
14
Questions
0
Helped
1566
Points
49
Yes u can go radio selection nd Divert calls using keypad witout joystick. First select any number on ur keypad, nd select more on right key, next use no2 on ur keypad nd select # key. here it wil display ur settings.. then select key no4. get list of settings.. then select no1 for call divert . again select no1 for divert always.. This s for divert calls. For rado select any number on r keypad, nd select more on right key, next use no2 on ur keypad nd select no9 for radio.
Joystick Key Mapper help needed?
A joystick key mapper is a software that allows you to customize the functionality of your joystick buttons and axes. It can be used to assign different actions or keyboard shortcuts to the buttons and axes of your joystick, allowing you to customize the controls of your games or other applications.
Here are the general steps to use a joystick key mapper:
  1. Download and install the key mapper software on your computer.
  2. Connect your joystick to your computer.
  3. Open the key mapper software and select your joystick from the list of devices.
  4. Assign different actions or keyboard shortcuts to the buttons and axes of your joystick. Some software may have pre-defined profiles, but you can usually create your own profile.
  5. Save your new configuration and test it by launching a game or other application that supports joystick input.
  6. If you are facing any issues, you can recalibrate your joystick.
There are many joystick key mapper software available, some popular software are Xpadder, JoyToKey, DS4Windows, Pinnacle Game Profiler, etc. You can choose the one that best suits your needs and is compatible with your computer and joystick.
It's important to note that not all games or applications support joystick input, so you may need to check if the software you want to use with your joystick is compatible with it.
Aug 06, 2022 • Cell Phones
1helpful
How to divert a call to other number
* Settings>call>call divert 1.All voice calls 2.If busy 3.If not answer 4.If out of reach 5.If not available N.B.from the above lists choose anyone that you wanted to use for your divert.
* Activate i) To voice mailbox ii) To other number choose anyone that you wanted to use for your divert. In case if you choose to other number There provide your number that you wanted to divert.
And see whether it's suitable for you or not?
Thanks for using FixYa All the Best!
2helpful
Driverts calls
Hi, You can use this instruction to activate and de-activate Call divert .Works on all phone
Turning Call Divert On
by Touch Tone phone
Step 1 Lift the receiver and listen for the dial tone.
Step 2 Press the Divert On button if using an Optus OneTouch phone, or dial *78 from any other touch tone phone.
Step 3 Listen for three beeps followed by a continuous tone.
Step 4 Dial the telephone number to which the calls are to be diverted.
Step 5 Listen for two short beeps, confirming the diversion.
Step 6 Replace the receiver
Turning Call Divert Off
By Touch Tone phone
Step1 Lift the receiver and listen for the dial tone
Step2 Press the Divert Off button if using an Optus OneTouch phone, or dial #78 from any other touch tone phone
Step3 Listen for two short beeps to confirm removal of the diversion
Step4 Replace the receiver.
Other Call Divert Options - Selective Calls
With selective call options, you can choose which numbers you wish to divert, accept or reject by adding these numbers to a list. You can list up to 30 numbers for each call option.
Turning On or Off Selective Call Options
Step2 Press the access code for the service you require. You will hear a prompt telling you the status of the service and how many telephone numbers you have on your list. To turn the service on/off press 3.
Access codes Dial
*63 for Selective Call Divert Dial
*68 for Selective Call Accept Dial
*60 for Selective Call Reject
Step3 For Selective Call Divert you will then hear the 'divert to' number that is currently entered. If this number is correct press 1. If it is incorrect, press 0, then re-enter the phone number you wish to have your calls diverted to. When turning this feature off dial 3 again.
Step 4 The feature is now on/off.
Step 5 Replace the receiver.
Note: You can divert calls to a local, national or mobile. However, you cannot divert calls to emergency, 0055, 1900, 008, 1800, 0050, 13, 1300 or international numbers.
Hope it helped.
Thanks for using fixya...
Jan 11, 2011 • Cell Phones
My w200i joystick is not functioning..i already replaced it but it doesnt work..
Use numeric pad at most function of the phone working
like if u want to select setting press #
............................radio press 9
..............................massage press 5
now .............................inbox press 2
now view the massage abd read it
massage is more than screen press more and 2 for forward
the remaing part is now form the back
now delete character for c button and read
Microsoft Combat Simulator Doesn't work with joy stick satik 290 pro. nothing works. it worked on xp. doesn't work on vista home.
You need the drivers from Saitek.com.
After selecting download > software, use the "Choose your Product Type) box. Select Joystick and you will find yours listed.
You need to know if you're using Vista or Vista64.
Install them, then plug your stick in. Should then work.
2answers
When im tapping my touch pad it doesnt work
Just above the pad is a small button, make sure that has not been accidentally pushed, that is the power button for the touchpad.
Re toshiba techra 8000
Some laptops have a touch pad between the keyboard and the edge of the laptop. This works like a mouse except you slide your finger around the pad to move the mouse pointer and the buttons next to the touch pad are the left and right buttons.
Other laptops have a small round button in the middle of the keyboard which is a mini joystick and it is used to move the mouse pointer around, it will have a couple of mouse buttons at the botom edge of the keyboard.
You can connect a normal mouse to your laptop, it is mush easier than using the laptop's touch pad or mini joystick.
2answers
Audio CD sound Prob
Various conditions may cause this problem. To troubleshoot, check the following:Microsoft Volume Control or your mixer program mute options and volume sliders.
Connect headphones to the stereo phone jack on your CD-ROM drive’s front panel; adjust the volume control settings on the drive. If there is sound from your headphones, check the CD audio cable connection from the CD-ROM drive to the audio card.
Ensure the speakers are properly connected to the audio card’s output connector.
Joystick port is not working
The audio card joystick port conflicts with another joystick port in the system. Disable the audio card joystick port, and use the system’s joystick port.
The joystick drivers, MSJSTICK.DRV and VJOYD.VXD, may not be installed. Uninstall the joystick, then reinstall to load the drivers. The drivers should come with the driver CD or floppy diskette with your sound card.
Computer hangs or restarts during installation
A hardware conflict may cause the computer to hang or restart during the installation procedure. Check the following to resolve the conflict:
A hardware conflict with another device in your system.
Previously installed sound card hardware or software needs to be removed.
The audio card is not seated in the slot properly.
PCI bus mastering devices may be interfering with the operation of the audio card. Temporarily remove non-essential PCI bus mastering devices.
Resolving hardware conflicts
Hardware conflicts occur when two or more devices contend for the same resources. Conflicts between your audio card and another device may occur regarding the I/O address, IRQ line, or DMA channel:
Right-click the My Computer icon on your desktop, and select Properties. The System Properties dialog appears.
Click the Device Manager tab. In the Device Manager, a plus sign(+) represents an expandable list of items. A minus sign (-) represents an expanded list. A circled exclamation mark denotes a conflict.
Double-click Sound, video, game controllers. A list of multimedia devices appears.
Select your audio card.
Choose the Propertis button.
Click the Resources tab.
Uncheck the Use automatic settings option.
Change "Settings based on:" if alternate settings are available.
Determine the conflict by reviewing the "Conflicting device list".
Select the conflicting item in the "Resource Settings" list.
Click the Change Settings button.
Use the mouse to select a new setting.
Select OK to close each of the properties windows, and restart your computer.
Audio card is not automatically detected
To manually configure your audio card for Windows 95/98:
Click "Start" on the taskbar, and select Settings from the Start menu.
Select Control Panel. The Control Panel group appears.
Double-click the Add New Hardware icon. The Add New Hardware Wizard dialog appears.
Select Next to continue.
Choose Yes to have Windows search for new hardware, then select Next
Select Finish, and follow the prompts to complete the new hardware installation.
CD does not automatically run when you insert it in the drive
To enable the "Audio insert notification" feature:
Click the Device Manager tab. A list of devices appears.
Double-click CD-ROM, and select your CD-ROM drive.
Choose the Properties button. The CD-ROM drive properties dialog appears.
Choose the Settings tab.
Click the "Auto insert notification" option to enable.
Select OK until all Properties dialogs are closed, and restart Windows for the changes to take effect.
No sound is heard from speakers
Verify the following:
Check the Microsoft Volume Control or the Audio Mixer Program mute options and volume sliders.
Check the volume control and power connection of the speakers, if they are amplified. (Refer to the speakers documentation for detailed information).
Ensure a hardware conflict does not exist between your audio card and another device in your system.
PCI bus mastering devices may be interfering with the operation of the audio card. Temporarily remove non-essential PCI bus mastering devices. If the device is a display card, upgrade the display card drivers, or set the card to the default Windows VGA mode.
If you are experiencing no sound only during audio CD playback, see "No sound is heard from audio (music) CDs" above.
Static sounds are heard in wave files
Check to see if the static sounds are heard in all wave files. If the difficulty occurs only with certain games, refer to the software manufacturer’s documentation. To troubleshoot static sounds heard in all wave files:
Try different resource settings for the audio card, or set the card to use low DMA.
Move the audio card to another PCI slot. Feedback from the power supply or another device may be responsible.
Logitech wingman joystick driver
Hi Momma_J
you dont have to search on the internet for the driver, its built in windows.
you just go to start>configuration>gamecontrollers
in that screen you press the button add, and search in the list for logitech wingman digital device and select it.
now press ok and let the computer find the joystick, after that you will be asked to restart the computer press yes and on the next startup your joystick work :)
it still not working
just contact me on my hotmail ([email protected]) and i will see what i can do for you
greets
stillen
I cant choose options with my joystick
You may not be allowed to delete certain files by using the player controls. Try deleting them using whatever music management system you are using right from the screen menu while your player is connected.
Top Sony Ericsson Cell Phones Experts
Sean Wright
Sean Wright
Kolbrun...
ZJ Limited
ZJ Limited
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
