Home Logo
Posted on Dec 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The installation seemed to go without a hitch until I turned on the water. The water would not enter the tank. It is like a valve is closed in the tank which will not permit water into the tank.(669709 Water Sense Round Dual Flush). Any suggestions?
Anonymous
Level 2:
New Friend:
  • Expert 118 Answers
  • Posted on Dec 06, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
118
Questions
Helped
33295
Points
149
Turn water off remove water line from toilet. point into a receptacle and turn on. if it doesnt turn on then the stem in the gate valve is broken. replace the shutoff valve.
How do you turn off water under sink to change reverse osmosis filters? I found the football shaped valve that goes to the hose. I turn the valve and water still runs so what am I doing wrong?
Open the RO tap and drain the RO tank (capture and use later). The tap will run a steady stream until tank empties. When tank empties the steady stream will switch to a drip, drip, drip,... This is normal and is the production output rate of the system.
If you capture the drips into a measured container a typical rate is 1 quart per hour, more or less given input line pressure and condition of system filters. Time how long it takes to capture a cup (8oz) and do the math.
The RO feed line is likely a piercing saddled type valve. It will take several turns (clockwise) to close the valve. Keep turning CW until it stops. With the tank empty (tap will drip, drip, drip,...) close the filter feed line valve and the drip, drip, drip will eventually stop, indicating the system no longer has water pressure.
How do you empty the fresh water tank on a Jayco Jay 806 popup? There seems to be no low point valves.
Look underneath the camper for a drain valve. Never seen a Jayco without a factory installed drain valve.
Jul 01, 2019 • RVs
We added anti freeze into our water hold tank. There is a pink film on the bottom of the tank. How do we clean the film out of the tank?
problem is there is an RV for your system. you will need to do the following.
Drain all holding tanks, fresh water and sewage
  1. Attach garden hose to fresh water fill and fill tank.
  2. Turn on pump switch and open cold water side of all faucet/ shower fixtures. Leave open until water runs clear. Repeat for hot water side.
  3. Flush toilet until clear water runs into bowl.
  4. Dump tanks again.
  5. Sanitize water system. use a water sanitizer
  6. If a water filter is installed, drain lines, remove filter assembly, clean and reinstall with new filter.
  7. When ready to use the water heater, turn by-pass valve to open position to allow water to enter and fill the hot water heater tank.
May 10, 2017 • RVs
Water not going into well water tank
Is the pump running when power is ON?
Put ear against pipe and listen for pump.
Have you installed a check valve?
Check vlave lets water pass through the pipe and enter tank, but the valve closes after pump shuts off and keeps water from falling back down into well.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
1helpful
Since I replaced the insides of my toilet with the fluidmaster 400 anti siphon, the water seems to no refill the tank after I flush the toilet.
You are going to have to adjust the valve you just installed. Most can be adjusted by pulling a ring close to the bottom upward and pulling the neck of the valve up, in turn adjusting the water level in the tank. There should be instructions in the box on how to raise the water level.
Jun 21, 2011 • Home
2helpful
We have a brand new rheem 40 gal elec water heater, after installation we have water leaking from the base of the relief valve, pooling up in the plastic fitting and making it way over the side all over...
Water heater should be set in a drip pan.
Otherwise, put 1 gallon bucket under TP release pipe to catch water.
http://waterheatertimer.org/Water-at-bottom-of-water-heater.html#drip-pan
When you say relief valve, I assum you are talking about brass valve located on top of tank or near top of tank. This is TP valve and a pipe connects to this valve and runs down to within 6" of bottom of tank. TP valve has a small lever on it.
If you are talking about tank drain valve located at bottom of tank, then add a comment.
Following information is for TP valve.
Dripping TP valve can be caused by 3 different thing:
1) Obstruction inside TP valve. Open TP valve for a moment to flush away particles and slowly lower lever back down. See if water stops dripping, if not, then replace TP valve
2) Defective TP valve: replace TP valve. Turn off electricity to water heater. Let heater cool for several hours so you do not get scalded. Close shut off valve located above tank on cold side. Open tub spout to relieve pressure, open tank drain or open TP valve and empty water below TP valve level. If TP is located on top of tank, not much water has to be drained. Tank is under press when hot, so be careful. Put teflon tape on new valve and install with big pipe wrench by turning clockwise until TP valve is very tight.
3) Overheating tank. TP valve is temperature-pressure valve. If tank water is over 150 degrees, the TP valve starts drizzling hot water to relieve tank pressure.
Lower tank pressure two different ways:
a) turn down thermostat
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html
b) install expansion tank on incoming cold water line
http://waterheatertimer.org/Water-at-bottom-of-water-heater.html#expansion-tank
MY GE PRESSURE RELIEF VALVE HAS JUST STARTED LEAKING. WHAT SHOULD I DO ? GE SMART WATER HEATER GELN0705CO3984
You can buy a replacement relief valve at any hardware or home improvement store. It's real name is a T&P valve or temperature and pressure relief valve. It always has a 3/4" inlet and outlet. It is a very easy procedure to replace. You will need a bucket, teflon pipe thread tape, and a 3/4" x 6" black iron or galvanized pipe nipple. To start the valve replacement, turn off the shuttoff valve on the cold water line. Then open the handle on the relief valve and drain water into the bucket, that is, unless you have a pvc pipe coming off of it into a drain floor, then just drain it without the bucket. Be careful, the water is hot! When the water level gets below the relief valve, it will stop draining. Then remove the pvc pipe, if applicable, and thread in the 6" pipe nipple to use as a leverage tool to remove the valve from the water tank. Turn it counter clockwise to remove. Then put teflon tape on the new valve, going from left to right with the valve threads facing downward. Wrap about 3-4 layers all around the threads. Then twist the new valve into the water tank clockwise and using the pipe nipple tighten by hand until very snug and outlet is facing downward, as before. Remove the pipe nipple and install pvc pipe, if applicable. Leave valve handle open and turn on the cold water until the valve starts spitting, then close the relief valve and let it fill up the tank. If you did it correctly, you are now finished! Good luck!
Douglas
15helpful
I have a ge reverse osmosis filtration system and recently lost pressure and tank capacity. I have only had the system about a month and my water has been tested fine. I did leave town for 10 days, could...
Make sure that all valves are in the open position.
Try to recharge the water storage tank. Here are the steps to follow.
* In General: When any type shut-off valve handle is positioned so that it is parallel or in line with the tubing that enters the valve, valve is OPEN. When handle is turned perpendicular to tubing that enters valve, valve is CLOSED.
Necessary Supplies:
1) Tire Gauge marked in 5psi increments (ie 5, 10, 15, 20psi, etc.)
2) Bicycle tire pump for standard type bike tire valve
To recharge RO system tank:
1) Close cold water feed valve (valve located at some point along the cold water line from street plumbing).*
2) Leaving RO tank valve on, turn tank on side & locate valve stem on bottom side.
3) Remove stem cap.
4) Drain all water out of tank through open RO faucet into sink. (Continue to leave RO faucet open throughout procedure)
5) If current tank pressure is insufficient to empty tank, apply tire pump to valve stem and pump 10 – 15 times. Exit flow will increase and then gradually decrease as pressure equalizes. Do not overcharge internal bladder of tank during this
procedure.
6) Repeat step #4 until tank is completely empty. (Tank is empty when additional pumping produces no more water)
7) At this point, adjust EMPTY tank to exactly 7psi. (Gauge reading midway between 5 & 10psi is sufficient)
8) Turn off RO faucet.
9) Replace cap on valve stem and reposition tank in upright position.
10) Open cold water feed valve.*
11) System water is useable immediately, however, tank will take 3-4 hrs to completely refill.
www.FreshWaterSystems.com: The Water Super Store: 1-877-335-3339
Have a kent r/o system dont know how to hook it up is there any way someone can help
Necessary Supplies:
3) Remove stem cap.
procedure.
Top Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Home Expert? Answer questions, earn points and help others
