Actiontec Electronics (GT724WGR) Retail DSL Wireless Gateway Router Logo
Jeff Paterson Posted on Mar 21, 2017
Is it possible to connect a land-line phone to the pk5000 modem that is connected to Qwest's fios in order to use the same phone number (account number) for both internet and phone service by using filters or plugging directly into phone port on back of modem?! I get no service when I plug my land-line phone into the wall jack with a filter or when I plug straight into the modem, with and without a filter. I do understand a filter is already within the modem but I'm just trying whatever. I would like to stay away from VOIP and headset/mic if at all possible. All I'm looking for is a local-only land-line (for as close to free as possible) so my two young daughters can use instead of always needing Mom's and Dad's cell phone to call local friends from school.
1 Related Answer
Anonymous
  • 13 Answers
  • Posted on Dec 04, 2007
SOURCE: actiontec gt701-wg Installation
You can use USB instead of Ethernet port but its not a common practise. Leave it empty then.
Magicjack doesn't always work right sometimes the phone works , sometimes I get an error 3002 message when I try to call out.
Actiontech what, they many vast models, and routers, and mix.
what are you exact connections here>
NO PC stated, HP model number, this is HP forum. so.....what?
no OS stated, opr. system , windows WHAT?
No modem models stated.
No ISP service stated,
what ISP, what service,? DSL> must I GUESS that?
My guess is not DSL no land line but it is possible to buy DSL
with Landline, disabled, I did for years.
or cable modem, ? uses COAX ! not 2wire twisted like DSL.
or are you doing the MAGIC jack , with NO COMPUTER owned
yes?
The magic jack does not plugin to any modem ethernet port
ever. its usb.
t
Broadband, high-speed internet, cable internet, DSL - WiFi, Fios fiber. and more , dial up? nah you dont have LAND LINE./
error codes,. the first page in the manual states !
Contact your Internet service provider to verify your modem allows more than one device to access the Internet if you receive error 3002 when trying to use MagicJack Plus. Some modems and modem/routers-in-one may not be compatible for use with MagicJack Plus if multiple devices are connected to your network.
We dont know what ISP you have nor the connection type
cable tv modem, DSL, FIOS what?
nor the modem you have , you never said,
this is far more complex
its not magic at all,
fire walls set wrong
ISP blocks you, at your mixed, router and modem
using the routers, USB port is a FAIL.
if you want great help answer what you have and what is connected
in details.
the MAGIC jack as 3 ways to connect,
USB or ethernet.?
Download
check internet connection on modem to see if it shut your off and restarted. If you have Qwest Modem Model # PK5000 - this model is causing disconnect problems with PS3
1helpful
2answers
Modem
Assuming that Windows has recognized the modem, and has loaded the correct device-drivers, Windows can use the modem.
You'll need to find an Internet Service Provider that provides "dial-up" service.
You'll need to have a land-line telephone (not a cell-phone) with your local telephone-company.
Connect a 4-wire cable (not an 8-wire Ethernet cable) from the "line" port on the modem to the telephone wall-jack.
Then, follow the instructions given you by your Internet Service Provider to configure your modem to connect to their dial-up server. Or, telphone them, and their Technical Support staff will guide you through the necessary configuration steps.
1helpful
Acer laptop not connecting to QWest PK5000
check your internet settings on the PC....
2helpful
Unable to connect to QWest PK5000 wireless modem
  1. Connect by cable to the PK5000
  2. Open A Browser Window
  3. Type in 192.168.0.1
  4. You should connect
3helpful
Got Qwest DSL internet and now PS3 can't connect to internet. "Access Point Was Not Detected" What do I do? Modem is Actiontec PK5000. Wireless internet works fine.
I found out that the ps3 is case senitive for the password so it there is caps in the password use caps..the qwest guy gave me a password like fff3093fhfhjh3r and I had to use FFF3093FHFH blah blah
The fax console is recieving the land line number
The problem is not in the configuration, but the fax connection. The fax modem port must be connected to the fax jack - not the same jack you connect your phone to.
3answers
Installing a internet modem
you open case
have comp turned completly off
install ethernet card into proper slot screw down
turn on comp goto control panel network setup wizard follow instructions from there
remember first your modem has to be recognized by your service provider first before you can get that connection and they give you the service to connect
say like cox qwest or other service provider
Top Actiontec Computers & Internet Experts
Jesse Walters
Jesse Walters
NOEL
NOEL
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
