I think you enter date in std Casio format:
PGM1 mode,
Type YYMMDD then press X/TIME button
If you go to Z mode and try a report, what happens?
If anyone needs a manual for a Casio QT-2000, C-tech collective have User/ Programming, service manuals here:
http://the-checkout-tech.com/manuals/cashregisters/Casio3.php
I have never used the software you have mentioned, so your machine has a special IPL installed to work with a local software package. You would need to contact a local dealer to have this set up.
To perform a daily report on the cash register,
Press X/Z mode button
Scroll down to Daily Z and select it.
You will see a list of available reports
Batch 1 report is the standard report with the info that most people need. Otherwise, choose a single report
Hay you helped me a lot already, come from it background spent xxxxxxx hours reading manual
still not sure whats happening.
Because we had no backup machine, had to initialise replacement till to defaults. (no IPL file)
However still getting E061 printer errors when trying to run reports.
Dont know how to program till, "I have no printer just a pc connected to Till only on com port 3".
any reports can only be displayed on screen.
If you could tell me how to turn this off that would be a great help
Thanks Again
Thanks for the response, Change date and time successfully THANKS, was using yes key and not X key to finalise input.
Still cannot get a read on Till or Hospitality software.
Z read
E061 Printer error - On Till
on Hopitality software- file 058 downloads - seems to be loaded something
Run report - report was cancelled or contains no data
Do not know had to read on qt2000 till
Originally setup using arrangement keys
Function key - arrangement - file 2 record 65
Any help on this would be much appreciated.
