Try disconnecting the drive and starting the computer. Switch off and reconnect and restart. The found new hardware wizard should appear and offer the option of searching the internet for a suitable driver and installing it automatically.
Go to this link and have a read up and see if it helps you out. support microsoft com
SOURCE: Gateway Pen Drive .... not recognized on Windows XP
@rickyostrom: If the drivers is not present then there would be a pop up to say that the hardware connected is malfunctioning... the user is saying his device is not being recognised... i dont think the usb protocol is the reason of the problem...
SOURCE: dvd / cd rom not recognized on my computer list
1) Go to Control Panel. Open the System Icon.
2( Click on Hardware Tab, then click on Device Manager.
3) The device manager will list all of your hardware that is on your computer.If you see a yellow? mark oryellow ! mark next to your DVD/CD rom drive,simply click on it then click Repair. It also may tell you that it is not recognozied. Follow the directions.
4) If you do not see this in your Device Manager go to Add Hardware in your Control Panel which is next to your Add/Remove Programs icon. Click on Add Hardware and it will scan for all hardware.
** This should take care of your problem.If not then somehow the actual connection in your tower has come loose. If so you must open your tower and look for a loose wire going to your DVD/CD rom drive.
*** Please let me know if this corrects your problem.Simply email me(Phil) at: [email protected]
I’m happy to help further over the phone at https://www.6ya.com/expert/phillip_293d34ebcf028794
SOURCE: my gateway desktop pc's sound won't work after installing windows
try to open your device manager and see if u have any ? marks (yellow) right click and restart it should work
SOURCE: GATEWAY SYSTEM OF SUPPORT DOES NOT RECOGNIZE MY SN OR MODEL NUMBE
call gateway that all i know
SOURCE: cannot restore pc from gateway disc
try this, shut down your tower. wait 1 minute.turnit on and keep tapping f11 until you get a recovery screen. then you have 2 choices to make rread them and make your decision..if you want to do full recovery use the 2nd choice this will take upto 30 minutes to fix but your computer will be good as new, what ever you do dont do anything to the computer when it is in recovry mode. it will let you know when it is done..let me know how you make out in 45 minutes tops
