OK, first you need to know the specs of both cars to have a guided guess. It is simple, find he the Horsepower (hp) for both, and the wiegh in pounds (Lb). Then for each car Divide the weight by the horsepower Lb/Hp and this will giive you how many pounds every horsepower has to carry. Compare results for both cars and the one with less pounds for each horsepower will have better chances of wining. Remember this is just a guided guess, since it works for cars in ideal perfect condition. There are other things which can change the results. One can be the hability of the driver to drive and to react in the start line.
You can help yourself by having your car loose weigh. For example, go to the race with a minimal amount of gas. Gas is heavy. Race alone in your car. Good Luck!! Be careful.
The timing belt and water pump should Absolutely be changed at 80.000km for the safety of you engine because if the timing belt breaks then you engine will be destroyed ,and also the valve clearance need to be adjusted. Also you need to change the fuel filter,Coolant flush,Transmission oil change. You can do all this just if you want to keep the car running for anther 100.000km. Peace be with you.
oil/filter 10k. main service/filters.20k.plugs 40k timing belt60k.or annually as above.oil is 5/40 semi synthetic to 50k then10/40 to 100k,then 20/50 thereafter.following this regime you car will last years..........
if its a timing chane or timing belt all he is going to do is change the oil everything chould come out the drain plug. Have your oil changed and enjoy your truck and save your $400.00 if it not broken don't fix it.... its a scare tactic to make money good luck CJ
Hello shaukathn: The factory recommended service interval to replace the timing belt. Is 90,000 miles or 144841.2 kilometers. This is a belt and not a chain driven engine. Please rate the reply as this lets us know you received the correct information. Thank You for using FixYa. Roger
