Microwave Ovens Logo
Posted on Nov 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi I have a 1 year old x7 When I attempt to make coffee the water doesn't go through the pod it comes out of the overflow in the base of the machine. With no pod in the water flows freeley from the correct dispenser The pods are being pierced and the batch I'm using have been working previously. I've also decalcified recently. I've checked the tubes and connections and all appears fine. I don't no what else to do please help!
Anonymous
Level 3:
President:
  • Master 2,702 Answers
  • Posted on Nov 28, 2010
Anonymous
Master
Level 3:
President:
Answers
2702
Questions
Helped
910943
Points
7895
Try a new pod,,,first if this is the fault your home and dry
1helpful
ALL LIGHTS ON MY KEURIG ARE BLINKING. I UNPLUGGED THE UNIT BUT WHEN I PLUGGED IT BACK IN, SAME PROBLEM. JUST BEFORE THE BLINKING STARTED, WATER WENT THROUGH THE BREW CYCLE BUT NO BUTTON WAS PRESSED NOR...
your coffee maker is damage.it has a faulty ic and transistor probably the whole little circuit is burned out .so my advise is to buy a new one if you dont want to get it repaired.good luck.
My Keurig at work and home (both a little over 1 year old) wont pump the hot water through so therefore won't cycle even though it says it is brewing.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Doesnt always make a full cup of coffee sometimes it doesn't even make a cup. Machine i s less than a year old.
heatman101
1helpful
We have a 12 cup Mr. Coffee about a year old. We put 4 scoops of coffee in and the appropriate amount of water. Every day, the filter overflows and grains of coffee get into the pot. How do we keep this...
Because I own a espresso company,I believe I can help you. There is several things that can cause a coffee machine to over flow. 1, putting to much coffee in, where water can not drain through filter. 2. The grind of the coffee, if it is ground to fine, like ground for espresso, will not allow coffee to flow through filter , drip machine that are not under high pressure like espresso machines have to have ground more course. 3, wrong type of filters, not fine enough for water to flow, or made for high pump pressure machine such as espresso machine . 4, putting to much water in, is not an issue on a mr coffee, because even if you fill it to full cup line, it would have nothing to do with filter over flowing, besides the coffee grounds always absorb some of the water anyway. In conclusion, my positive professional diagnose is Grounds of coffee to course, and 4 scoops seem a bit to much for a filter of a mr coffee machine that holds only 12 cups. To test this is make a pot same way and use only two rounded scoops and see what happens, if does not over flow that solves that. But your saying I want it stronger, believe me I know. I too like my coffee strong and a flavorful . I have that solved too. Go to a good walk in espresso shop, like a star bucks, tell them you want some good strong blend and have it ( Ground for Drip) and then still only put two rounded scoops, it takes less do to the blend and kind of coffee. Please let me know if my advice worked, thanks mike. oh notice my screen name of mc1 bean, now you know, I know what I am talking about :)
My Keurig Elite brewer comes on and the heating light is on but it doesn't draw water up through it.
heatman101
We have an 8 year old Alessi Nespresso machine, and it is leaking water at the base. It seems to leak only when the machine is in use. There is not any water at the base of the water container, so i am...
I have the same model, same age, same problem. It appears to be the seal between the metal heating coils, and the plastic switch that selects steam or coffee. Possibly caused by no cleaning the injector hole with the tool provided with machine (which causes a lot of back pressure). On mine, the screw that holds the switch to the heater has corroded and can not be unscrewed, so not possible to access rubber seal, and repair. May be tricky since this is plastic sealed to hot metal with a rubber gasket. So fo now, i unscrewed the black base plate on the bootom, and set the Alessi in a tray. THen just wipe up water after use.
Our Magimix 11400 (less than 2 years old) heats normally, the vapour nozzle fonctions too, but our problem : when the coffee selection switch is put on the motors starts up, seems to fonction properly but...
Hello Pat, You have a common occurring problem. Your tubing in clotted. The least expensive solution is to use regular vinegar instead of water for several cycles, no coffee grounds. The clot will dissolve and water flow will return to normal. Cycle just water until no taste or smell of vinegar is present. Have some HOT COFFEE.
Water will not pass through the capsule?
Try running vinegar in stead of water, without the coffee thru it several times.
Top Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Microwave Oven Expert? Answer questions, earn points and help others
