SOURCE: hp c7180 printer does not recognize new ink cartridge
be sure you removed tapes from cartridge.
Follow the instruction and reinstall new cart.
SOURCE: printer c7200 hp photosmart has new cartridge but
Get your printer little bit serviced...and this problem you are tell about seems to be of the buffer device in the printer it needs to be replaced...
SOURCE: Printer thinks cartridges empty
Unplug your printer from the computer and then the power supply. Remove the inks from the printer. Plug the printer back into the computer first then connect the power supply. Install the inks "very slowly" one by one and then check the levels, they should now read full. Thank you, Dana
Testimonial: "You have just saved me sooo much time and money!Thank you."
SOURCE: Printer won't recognize new ink cartridges
Follow this simple instructions:
Remove all the cartridges, clean the contact points on the cartridges and on the printer using soft brush/cotton dipped in alcohol/acetone/spirit. While they are drying, reset your printer; Turn it off > Disconnect usb cable, power cord, inthernet cable; >remove the papers from the tray >open the back panel door (the rear door where you clear paper jam). Also turn of the main switch which the dc adapter plugged in. After keeping it Off for about 5 minutes, turn on again using only the power cord, and again leave it on for few minutes > turn it off > connect all the cables > again turn it On and keep pressing the power button while it boots up. Now you can install the cartridges.
Good luck.
Thanks for using FixYa.
