Check the memory card in the PC and confirm if the card is working. If so the memory card slot must be checked for poor connections. If not the phone is not detecting as there is some software issues. Have the phone reset to factory settings by typing 12345 into the restore to factory settings in phone settings. If there is no result the phone software must be reinstalled.
Get help from Nokia
SOURCE: can i lock the memory card nokia 3110 clasic
yes you can lock it. go to gallery, then sellect mmory card, then option then select aet password. tnx
SOURCE: forgot password of memory card of nokia 3110
my nokia 3110c memory card passwerd forgot solve my problem
SOURCE: I am using nokia 3110
For memory card problem:
Try to use another memory card for testing and if it shows the same problem you have to go to the service center because they will replace the damaged memory ic.
For sms and phone number problem:
You can try restoring it to factory settings. If the problem still persist, try to update your firmware.
