I have a 1994 Nissan Sentra. It has approximately 179,000, miles. First it start cutting off when I make turns to the left, but would start right back up. Now it cutting off when I make a complete stop and when I make left turns. This have been going on for at least 3 -5 months. I don't know what to do, could it possible be my Air Flow Meter needs to be replace, if so the part along is over $600.00. This cutting off problem have me weary of going anywhere. Please help.
Get a Chiltons/Haynes manual for your make/model/year and go to the troubleshooting section. It sounds like the same thing my little rabbit did years ago. Turns out it needed new fuel filters and the fuel tank flushed. The gunk kept impeding fuel flow. Didn't do good things for the fuel pump either.
SOURCE: 2001 Nissan Sentra 1.8 l engine won't start.
Is the check engine light on?? You may have a stretched timing chain, but the only way to check that is to remove the valve cover and look at the timing chain tensioner to see if it is way out of the housing. We see chains on those stretch and cause a running issue like the one that you are descibing, because its out of time. Just a pointer, not a solution, but something worth looking into.
SOURCE: 1999 nissan sentra gxe headlight problem
do you have the right light bulb? i own a 98 sentre and
it takes a 9004 bulb, but walmarts computer said to use 9007. That made the high beam censor stay on till i replaced it. if you look at the bulb you can tell if it is a dual or single beam bulb.!!!!
SOURCE: I have a 2004 NISSAN SENTRA SE R SPEC V (Nismo), my car sputters
You have 2 Problems, First problem batteries dying you have to make sure connections secure and alternator is charging your batteries (go to an Autozone or Discount advanced they will tell you). The Sputtering is either a bad SPARK PLUG or a damaged Cable going to the spark plug..Change them every 2 years.
SOURCE: 2000 nissan altima with scanner codes p300 , p300 and p1320
look up the codes if they are multiple missfire codes then more than likly you have a bad head gasket
SOURCE: how to replace a nissan pulsar N15 GA15 air flow
remove 4 scrwes at air filter box and big hose clamp remouve air flow meter
Testimonial: "Yes, gave me just what I needed"
