Use this procedure to reprogram the remote transmitters
1. Turn "on" the ignition.
2. Press the Valet Switch 5 times and wait for horn confirmation of entry into programming mode.
3. Press and release the "Lock" transmitter button on each remote to be coded (one at a time).
4. The system will respond to each with an audible confirmation.
5. Turn "off" the ignition to exit program mode.
The unit should retain the transmitter codes almost indefinitely and should not require reprogramming periodically. I suggest that you call Omega Research and Development, the makers of Excalibur, to see if your unit can be replaced. Their number is 800-554-4053 and their is www.caralarm.com
