20 Most Recent Prestige Remote Start Questions & Answers
yes i think it might be in valet
Prestige Remote... | Answered on Dec 14, 2017
Typically a car remote does not have to be reprogrammed to replace the battery. Check the car's owners manual to verify the battery is a CR1229. I don't know of any 1229 number but I do know a CR1220. Verify the number and you can buy them at just about any store...from Walmart on.
Semper Fi,
Z
Prestige Remote... | Answered on Aug 08, 2017
assuming its an aftermarket voxx alarm your talking about either notify the old owner about problem and see if a remote is available or notify voxx support for assistance the following links are install wiring and owner manual
http://media.datatail.com/docs/installation/184503_en.pdf VOXX Electronics APS997 Home
Prestige Remote... | Answered on Jun 02, 2017
This is most likely the key that is on your window. the contact may have come loose or slightly out of alignment. Try that first then take it back to the installer. I am sure they will get it working again without a fee.
Prestige Remote... | Answered on Feb 04, 2016
You did not mention the year/make/model of your vehicle but, the issue appears to be the factory alarm. The installer failed to make the connection. If you intend to make the connection yourself I would need information pertaining to the vehicle. The (-) pulse before start wire for Prestige remote starters is black with a blue stripe. It is in a 4 pin connector at the module. This wire can be used to disarm the factory alarm before the remote start sequence.
Prestige Remote... | Answered on Dec 30, 2014
The only 2 pin connector is for the transponder bypass module.
These wires are for the following outputs
2 Pin Transponder Output Harness #1123292
1) Red Battery (+) 100mA
2) Black (-) Output While Running 100mA
This connects your transponder key module to the starter, it activates the module when cranking to simulate a key.
a: When selected for while remote start on, the Black wire will be active at the same time ign. 3 becomes
active, and will remain active all the time the unit is operational under the control of the remote start.
b: When selected for output during the start sequence, the Black wire will be active at the same time Ign.
3 becomes active, and will remain active until the vehicle has started. This will be used for one time read
transponder circuits.
c: When the unit is selected for until ignition off, the Black wire will become active at the same time ign.
3 becomes active and will remain active even after the key take over and until the ignition in the vehicle is
turned off. This will allow the unit to be used for continuous read transponders circuits
Prestige Remote... | Answered on Nov 15, 2014
This would be difficult to give an accurate diagnosis without full details like:- what model alarm system or vehicle this is for!
sounds like it might be the starter connection to the key switch is disconnected!
Prestige Remote... | Answered on Oct 13, 2014
Prestige Remote Start Logo
208 questions posted
Top Audiovox Vehicle Parts & Accessories Experts
Jim Goldsmith
Jim Goldsmith
xxxxxx xxx
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Audiovox Vehicle Parts & Accessories
Most Popular Question
gmc yukon aps997 installed not me now
  • Vehicle Parts & Accessories
