Toshiba DKT3210-S Corded Phone Logo
Posted on Nov 08, 2010
I cannot get my DKT3210R Toshiba phone off of Do not Disturb. I have the user manual and have followed the instructions to no avail. Help!!
4 Related Answers
Anonymous
  • Posted on Jul 20, 2008
SOURCE: Do Not Disturb
i still cannont get the do not disbrub off. ??? any other help?
Anonymous
  • Posted on Aug 21, 2008
SOURCE: Toshiba TS608 Mobile/cell Phone User/Instruction manual/guide
Try this:
http://www.toshiba.co.jp/product/etsg/cmt/english/asian/dl/TS30_English.pdf
Anonymous
  • 5 Answers
  • Posted on Jun 24, 2009
SOURCE: How to turn off DO NOT DISTURB Samsung DS-24D
Press 400
Anonymous
  • Posted on Nov 07, 2009
SOURCE: how to cancel dial lock on KX-T2373MXW
copy image very bad what is problom
My calls go directly to voicemail on edge 120
Normally when calls go directly go to voicemail, there are a couple things why this happens:
- Extension are unavailable/busy
- Call forwarding/Do Not Disturb are on.
If you do have call forwarding/Do Not Disturb on, please consult your user's manual for detail instructions since there are several options for call forwarding (Forward All Calls, Forward Busy, Forward N/A, etc.).
Where is the "do not disturb" setting on a Samsung Rugby?
This is related to the Push to Talk function:
PTT Settings
1. In Idle mode, press Menu -> PTT and press the Select soft
key or the key.
2. Select PTT Settings and press the Select soft key or the
key. Choose from the following options:
• My Availability: this option allows you to change your Availability
status. Use the Up or Down Navigation key, to highlight Do Not
Disturb or Available and press the Select soft key or the key.
You can find the manual here:
http://images.comparecellular.com/phones/1362/samsung-rugby-ii-user-guide.pdf
1helpful
2answers
Hank419How can I get an owner's manual for the durabrand phone Mod. # ph-3238 (HAC/VC)
Find the PH-3238 user manual at http://manualfox.com/link/durabrand.htm
Apr 21, 2011 • Cell Phones
Program "Do not disturb" on business phone
It's pretty straightforward. You pick a spare button, dial FEAT 00 press the blank button (with a light) and press FEAT 01. There are considerations that I'll reproduce here.
Do Not Disturb (F01) 8
Use this feature to be able to press a programmed button to prevent incoming calls for the
extension from ringing (lights still flash). When Do Not Disturb is on, outside callers hear ringing
while inside callers hear a busy signal. You should use Do Not Disturb only if someone answers
outside calls for your extension when you do not answer them.
Considerations 8
Do Not Disturb is available only on system telephones.
Do Not Disturb requires a button with lights. When the Do Not Disturb feature is on, the light
is also on, indicating that the telephone will not ring.
■ Use Do Not Disturb when you do not want the auto attendant or the voice messaging system
to transfer calls to you.
■ Use Do Not Disturb if you are assigned to a Hunt Group and you leave your desk, so calls to
the Hunt Group will skip your extension and ring immediately at the next available extension
in the group.
■ To avoid missing calls when Do Not Disturb is not needed, turn it off.
■ If Do Not Disturb is active at a doorphone alert extension, the person at the doorphone hears
signaling, but the alert extension is not signaled.
■ Unanswered calls that are transferred from an extension with Do Not Disturb active ring at
that extension if they transfer return.
■ Extensions with Do Not Disturb activated do not receive Caller ID information, unless the call
is answered.
■ Users with Automatic VMS Cover Assigned or with VMS Cover turned on can activate Do
Not Disturb
to Send All Calls immediately to their voice mailbox.
■ Users with Call Coverage turned on can activate Do Not Disturb to Send All Calls
immediately to the covering extension.
■ You cannot use Call Screening (F25) when Do Not Disturb is turned on.
Carl
From the manual: You need to program a button with FEATURE 01.
¦ Use Do Not Disturb when you do not want the auto attendant or the voice messaging system
¦ Use Do Not Disturb if you are assigned to a Hunt Group and you leave your desk, so calls to
in the group.
¦ To avoid missing calls when Do Not Disturb is not needed, turn it off
Carl
1helpful
Our company has produced Auto Attendant messages for a client's phone system [Toshiba DKT2020-SD] and need step-by step directions for loading them. The client has not been able to provide these...
You would have to dial your voicemail extension. Usually this extension is 850 or 555. Once greeting starts you need to press *. It will then ask you for the user ID and password. User ID should be 990 and password should be 990997. Once in the mailbox you will have to follow the instructions on entering in your message. Below is a site with Toshiba manuals that may help.
http://www.wedophones.com/ToshibaManualsLead.htm
3helpful
Ge cordless phone model #28111ee2-a,the face of the phone says do not disturb,how do i get it off?
CLICK HERE for your owners manual.
The Very Last paragraph states the following...
Do Not Disturb (DND)
DND allows you to mute the ringer on all handsets.
In the standby mode (phone handset off and in cradle), press the do not disturb button on the base. The DND indicator will light and DO NOT DISTURB shows in handset display.
To cancel, press the do not disturb button again.
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
2helpful
GE cordless dect 6.0-do not disturb
According to the instructions, you only need to press the "do not disturb" button again. The button is on the base (not the phone).
7answers
Do Not Disturb
hahahaha Thanks for the advice! I've been trying and trying to fix this problem for days now. "Do not disturb" button - wow, do I ever feel like a ****.
Top Toshiba Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
