If possible, pull the horn relay, use jumper wire on switch side of relay, right side in diagram. If the horn sounds, it's not the fuse. Sometimes these diagrams don't post, for some reason? good luck
there should be only 1 fuse for the horn, if it works but not from the steering wheel it very possible and likely the horn switch in the steer wheel has malfunctioned. you could run another horn switch or replace that one but if the horn relay works and the horn sounds off then its the switch. good luck https://www.6ya.com/mrmmike
These are books containing info on repair, service, troubleshooting, parts info, assembling dissemble, removal, error/fault codes, wiring diagrams and everything on any vehicles cars, atv, trucks. forklifts, boats, excavators etc
Check ALL the fuses with a 12 volt test light.
Change all that are burnt.
Also.....check the wire going to the horn (at the horn) with your 12volt test light if the fuses are good.Have someone push the horn button.
It might be the horn or horn relay that is defective.....not just the fuse.
I replace more horns than fuses.
