I have problems on my K550i those are showing several codes representing eg. F4:2399 for Call, F4:2458 for Menu and so on. These codes are excluding for SMS. I had try to master reset my phone, but it's not work and still showing the same codes. How can I solve this problem? Please...
a programme called setool lite could reset the code back to 0000
download setool lite here: http://www.4shared.com/file/VSqGxHQu/SE_Tool_2_Lite_111.html?s=1
turn antivirus resident sheild off (it will report this programme as a false positive) when downloaded extract file with winrar
turn phone off and remove sim and memory card do not turn phone back on! select k550 in the list press 'identify' on setool lite press and hold 'c' on the phone and plug usb cable in
it will ask for driver which is in the setool lite folder so direct it to there
after driver installed setool will then read your phone and displa info on the screen
as soon as that has finished unplug your phone, put sim and memory card back on and the security code should be reset to 0000
To protect your phone from unauthorized use, just follow these simple steps. Once activated, your phone will require the user to enter a password each time it?s turned on. Go to Menu > Settings > General > Locks > SIM Lock > Protection. To turn your PIN code request on, you will be prompted to enter a 4 to 8 digit phone code (that you create) Call Cincinnati Bell Customer Care at 611 to obtain a PIN/PUK code to enter at the prompt. here is the link k550i Happy new year and Happy Sunday
Hi Ok try this it may work. 1.Go Menu Type in *2864 Type in 10 Code WSW00 shows Type in 51 Code WSW51 0000001 will show Try different values, eg change to 000000 or 0000010 BUT remember original code to get back to To exit type 99 Also can try. Solution: ·Machine off ·Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode. ·Press 80 ·Press the “mono start” button several times until you see “purge: xxxx” ·Press “2783” in order to reset the purge counter. You will see: “purge:0000” ·Press the "stop" button. ·Press “99” to exit the maintenance mode. Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one
All The Best: Pineworks ·
Hi There 1.Go Menu Type in *2864 Type in 10 Code WSW00 shows Type in 51 Code WSW51 0000001 will show Try different values, eg change to 000000 or 0000010 BUT remember original code to get back to To exit type 99 Also can try. Solution: ·Machine off ·Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode. ·Press 80 ·Press the “mono start” button several times until you see “purge: xxxx” ·Press “2783” in order to reset the purge counter. You will see: “purge:0000” ·Press the "stop" button. ·Press “99” to exit the maintenance mode. Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one
You can get the unlock code for your Sony Ericsson K550i from www.Theunlockarena.com . This site provides excellent service in unlocking solutions. The unlocking codes provided here are 100% accurate and very affordable. The unlocking process is very simple here. Here are the steps for unlocking Sony Ericsson K550i,1 - Switch ON your Sony Ericsson K550i without any SIM Card, 2 - Press the left arrow key/button once, 3 - Press the button * twice, 4 - Press the left arrow key/button once, 5 - The message "Personalize with MNC2" will appear, (or you will have displayed an unlock menu, select the lock you want to unlock) 6 - Enter the Unlock Code.
After a PIN is entered 3 times incorrectly, the phone will then prompt for the PUK (PIN Unlock Key). After 10 incorrect entries of the PUK, the SIM (Subscriber Identity Module) card will be rendered unusable (PUK Blocked). At this point, the SIM card will need to be replaced.
Contact your service provider and explain your situation. Do not attempt to enter the PUK unless you are prompted to do so by the representative. Most local service centers can do this for you, sometimes for a fee for the services and the SIM card if it needs replaced.
Hi Ok try this it may work. All the best good luck 1.Go Menu Type in *2864 Type in 10 Code WSW00 shows Type in 51 Code WSW51 0000001 will show Try different values, eg change to 000000 or 0000010 BUT remember original code to get back to To exit type 99 Also can try. Solution: ·Machine off ·Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode. ·Press 80 ·Press the “mono start” button several times until you see “purge: xxxx” ·Press “2783” in order to reset the purge counter. You will see: “purge:0000” ·Press the "stop" button. ·Press “99” to exit the maintenance mode. Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one
