Which light ? on the instrument cluster or the passenger side .
If a lamp fault code (LFC) is reported by the customer but is not present when the vehicle comes in for service, follow the Diagnostic Instructions procedure in this section to identify the intermittent DTC.
Lamp Fault Codes
When the restraints control module (RCM) detects a system fault, it will cause the air bag indicator to flash a coded sequence; a lamp fault code (LFC). The code is 2 digits. The first digit is flashed with a 0.5-second interval between pulses. There is a 2-second pause before the second digit is flashed which also has a 0.5-second interval between pulses. There is a 5-second pause between each display of an LFC.
Each LFC is flashed 3 times after which the air bag indictor will remain lit for the remainder of the key-on cycle. If there are multiple LFCs, each LFC will flash in order of priority. Lamp flash code 34
B2292 d
34
Restraint System - Seat Belt Pretensioner Fault (Passenger Pretensioner Circuit Fault)
Go To Pinpoint Test R .
PINPOINT TEST R: LFC 33 AND 34/DTC B2292 - RESTRAINT SYSTEM - SEAT BELT PRETENSIONER FAULT
NOTE: Most faults are due to connector and/or wiring concerns. Carry out a thorough Inspection and Verification before proceeding with the pinpoint test.
NOTE: The retractor pretensioner connector keying is different between vehicles. The retractor pretensioner connector shown in the following pinpoint test is equipped on the Five Hundred, the connector equipped on the Freestyle and Montego is similar.
Test Step
Result / Action to Take
R1 CHECK FOR CONTINUOUS OR ON-DEMAND DTCs
WARNING: Restraint system diagnostic tools are for service only. Tools must be removed prior to operating the vehicle over the road. Failure to remove restraint system diagnostic tools could result in injury and possible violation of vehicle safety standards. WARNING: Do not handle, move or change the original horizontal mounting position of the restraints control module (RCM) while the RCM is connected and the ignition switch is ON. Failure to follow these instructions may result in the inadvertent deployment of the safety canopy and risk of personal injury. WARNING: Never probe the connectors on the air bag module. Doing so can result in air bag deployment, which can result in personal injury. WARNING: The safety belt pretensioner is a pyrotechnic device. Always wear safety glasses when repairing an air bag equipped vehicle and when handling a safety belt buckle pretensioner or safety belt retractor pretensioner. Never probe a pretensioner electrical connector. Doing so could result in pretensioner or air bag deployment and could result in personal injury. WARNING: Never probe the electrical connector on a safety canopy module. Doing so can result in safety canopy deployment. NOTE: If a seat equipped with a supplemental restraint system (SRS) component is being serviced, the SRS must be depowered. NOTE: After diagnosing or repairing an SRS, the restraint system diagnostic tools must be removed before operating the vehicle over the road. NOTE: The SRS must be fully operational and free of faults before releasing the vehicle to the customer.
- Enter the following diagnostic mode on the diagnostic tool: On-Demand Self Test.
- Enter the following diagnostic mode on the diagnostic tool: Flag DTC B2292/ Record All Flagged Faults.
- Enter the following diagnostic mode on the diagnostic tool: Retrieve/Flag /Record Continuous DTCs.
- Was DTC B2292 retrieved during the on-demand self test?
Yes
This is a hard fault. The fault condition is still present. This fault cannot be cleared until it is corrected and the DTC is no longer retrieved during the on-demand self test. GO to R2 .
No
This is an intermittent fault. The fault condition is not present at this time.
Your best bet , take it to a qualified repair shop .
no obvious draining problems exist
