Since you didn't say which engine you have, I've pulled torque specs for 3 different engines. Also, since I can't include a diagram showing the relative locations of the numbered head-bolt locations, it would be a good idea for you to purchase a vehicle specific repair guide that will show this info.
Take particular note about the TTY (Torque to Yield) bolts used on 2 of the 3 engines shown. It is said that new head bolts MUST BE USED when head is replaced or re-installed to obtain the proper torque.
B2500 4 Cylinder
Torque sequence: --------- ' 10 6 2 4 8
' front ' ' ' 7 3 1 5 9 ' -----------Step 1: torque in sequence to 51
Ft/Lbs Step 2: torque again in sequence to 51 Ft/Lbs Step 3: final
tighten all bolts an additional 90 to 100 degrees recheck final
torque in sequence *** CAUTION ***engine uses Torque To Yield head
bolts (TTY) that permanently stretch during the initial installation.
New head bolts must be used when cylinder head is replaced or
re-installed to obtain proper torque.
B3000 3.0 6 Cylinder
Torque sequence ---------- ' 6 4 2 8 '
' ' ' 5 1 3 7 ' ---------- Step 1: torque to 59 Ft/Lbs Step 2: loosen
in sequence (1) full turn Step 3: torque to 41 Ft/Lbs Step 4: torque
to 73 Ft/Lbs
B4000 4.0 6 Cylinder
Torque sequence --------- ' 5 1 3 7 ' '
' ' 6 4 2 8 ' --------- Step 1: torque cylinder head bolts in
sequence to 26 Ft/Lbs Step 2: torque cylinder head bolts to 56 Ft/Lbs
Step 3: turn cylinder head bolts in sequence an additional 90-degrees
recheck final torque in sequence *** CAUTION ***engine uses Torque To
Yield head bolts (TTY) that permanently stretch during the initial
installation. New head bolts must be used when cylinder head is
replaced or re-installed to obtain proper torque.
Good luck with this job!
